Really small Dremel-type tool for porting small-bore 2 strokes?
stanleyoutdoors
Littleton, CO
I need to port a 100cc 2stroke cylinder and my dremel with angle head adapter just won't fit (like in pic below).
Any suggestions?
Thanks
driftpin
Do they still make the flexible wand attachment?
Was my thought also - I got that as part of the kit I bought many years ago, and have been surprised how much I've used it.
I had a Dremel wand for many years, it sat, unused. At some point, I tried it out, and it's stayed in-place ever since. I know a Dremel's more of a light-duty use, that's OK, it's done jobs for me that I couldn't have done otherwise, except for buying something much-more expensive.
shoot summ
Won't work for porting the transfers on a small 2 stroke, the right angle tool posted by JAR944 is the only good solution. Might try to find someone that would let you borrow their setup(I judiciously loaned mine a couple of times), or just pay to have the porting done. I'm assuming since the OP is asking they know what they are doing, but porting isn't a "bigger is better" task, and with a 100cc you can go from good to really bad in a mm or two.
stanleyoutdoors
Littleton, CO
You are correct. I don't mess with size or shape much for that exact reason. Mostly just smooth everything.
shoot summ
You can get long shaft 1/8" burrs that work really well for getting in some of the places. It's fun to do, I have spent many hours porting cylinders in the past. Honestly though if you aren't changing the size/discharge/duration of the transfers the work you are doing is more for your fun, it really isn't going to net you a seat of the pants improvement.
stanleyoutdoors
Littleton, CO
I've had a lot of good luck with just smoothing everything on 250's. More power everywhere, but especially at high rpm.
I'm typically looking for more low to mid range for Enduro, so I often mill the base of the cylinder and correct the squish and comp ratio in addition to smoothing. That's what I'm considering doing on a Husqvarna 105 (85 with big bore) for my daughter. I have gone all-in with epoxying the transfers, stuffing the case, etc, but that's a lot of work. Still scared to change the port shapes though. As you alluded to, there's too much chance of really screwing it up.
jar944
Northern VA
Read everything on the internet from Jan Thiel (passed away this week) and Frits Overmars.
There is a ton of information they both shared about their work at Aprilia over on the pit lane forum across a few threads (part 1-5) that spanned the better part of a decade.
Or just google "All that you wanted to know on Aprilia RSA 125, and more, by Mr Jan Thiel and Mr Frits Overmars"
Pinne
I think a flex shaft rotary would be the way to go for this. Foredom is the brand that I see most people using for high precision work - lots of jewelers use these: https://www.foredom.net/product-category/flex-shaft-tools/
The motor is obviously much more powerful than a Dremel, they are much easier to manipulate, and they're usually foot pedal operated so you have greater control than needing to adjust speed on a Dremel.
I picked mine up for about $150 second hand with a lot of attachments, if I remember correctly.
rharman
SoCal
For smoothing/polishing, I used a slotted mandrel with emery cloth with valve lapping compound and Simichrome.
stanleyoutdoors
Littleton, CO
I'll look into that- thanks.
I have been going off A. Graham Bell's "2-stroke performance" book as well as a few things a top karting tuner taught me.
