reasonably priced vernier caliper
whateg01
doo dah, kansas, usa
I bought a vernier height gauge and still have it. Used it quite a bit before getting my mit dial version. I think it's good to be able to read a vernier scale but I wouldn't want to go back to it for most stuff.
tool_scrounge
Southern California
I like keeping vernier calipers and a tape measure in the glovebox of my vehicles. You never know when you will need them. So not needing a battery is a requirement.
I buy vernier calipers with a widely spaced vernier like a shown. It is much easier to read than the ones with closely spaced lines.
dscheidt
-Not wanting to be quarrelsome but no caliper, by nature of the design, should be trusted to read sub-thou for accuracy regardless of whether the display allows 4 decimal places (.xxxx) or not. This would be especially true for a $10 caliper. How many people can actually quantify what sub-thou is? Even taking a reading off a gauge block with calipers can be misleading and is no guarantee of accuracy.
sure, but that is a different problem. The scale and read head are capable of sub thou accuracy (and precision), were they installed in some instrument that could support that. So, I guess the better way to say this is "why you can get a $10 digital caliper that's as accurate as it's practical to make a caliper.", but that's a bit cumbersome.
Jgaz
For $1.99 I'd have some pretty low expectations...
I carried one of these in my travel kit when I worked in the vehicle dynamics dept.
Never found a quicker way to determine what diameter sway bar was on a vehicle when there was a question.
Quick, easy to use, and close enough to tell the difference between a 22 and a 24mm diameter bar.
Outahere
Idaho
...Starrett, Mitutoyo, Fowler, Werka ,INSIZE, NEIKO, Hardell, Kynup, Quinn, VINCA, S&F, Jiavarry, Johnson Level & Tool, Louisware, Pittsburgh and Adoric. Calipers tested for accuracy and smoothness in measuring hole diameter, depth, square and round objects...
