How hot is she running? Check the engine oil to see if there is water mixed in, telltale sign is it usually looks like chocolate milk indicating one of the head gaskets will need to be replaced. How many miles are on the suburban? Have you flushed the system since you owned the SUV or know when it was done last? Easy do it yourself fix is to check the coolant in radiator, is it full? what color is the coolant, if it is Rusty brown , I would flush the system and while your at it change the thermostat for piece of mind. Check your radiator hoses for leaks(cracked or dry rot, should be replaced), make sure your clamps are all tight and not leaking. Hope this helps, and what 619diofan said
