supratreo
Not sure if this is the correct forums but its the closest i could find.
below is a drawing for rebar and concrete work i need to do. i just wanted to see if someone could confirm I'm reading it right.
holes is 18x43
rebar is #4 with the 4 top sections spaced 4" apart and the lower 2 at 12"
also states that there should be min. 3" clear cover on all steel embedded in concrete when cast against soil (which it will be).
so I'm safe to assume the rebar would be 12" square?
thank you
holes is 18x43
thank you
