Hey guys just want to know what you think about my idea, im trying to rebuild a carport and want to know if its ok structurally........
To start off i have 6 115mm x 115mm (4.5" x 4.5") at 3 meters long, i will dig down 650mm (25.6"), so i can stick the support beems donw 600mm (23.6") deep, 3 on one side and 3 on the other and the distance between them from center to center will be 5585mm (18.3 ft). The right side postes witch is closes to the house will be 2400mm (7.8 ft) high off the ground, and the other postes will be 2200mm (7.2 ft) high off the ground witch will give me a slight slant away from the house.
Next i will be putting up 3 cross beems 190mm x 45mm x 6000mm (7.5" x 1.8" x 19.7 ft)from one side to another and will be held in with M12 x 130mm (5.2") bolts.
Then will go on the horizontal beems witch i have 14 peaces of 90mm x 45mm x 3000mm (3.5" x 1.8" x 118") and thinking of joining two of them together to make it 6000mm (19.7 ft) witch will sit over the cross beems and will be held in with 75mm (3") square screws.
Last but not lest i will through on polycarbonate greca panels on top.......
I hope i am explaning this as much as i can........any help is better then nothing would love to get intake on this thanks every one
Young
Young
