So I have an older drill press. I don't want to replace it as it has always worked great- and I don't want to spend what it will take to get the same power and speed. But...
The column is too short. Only about 24". So I measured the column and got an inexpensive 72" of 1 3/4 inch steel pipe. Genius, I thought, to turn my old press into a floor press for $20 -except the new column is a true 1.75" and the old one is a couple thousandths less. So the base, head, and table don't fit.
I used a narrow belt sander to take a fraction off the top and bottom of the new column, and now the head and base fit perfectly. See the problem? I don't want to take the hours to grind the whole column for the table.
Possible solution 1: take hours and grind FEET of the column for the table. Rejected because of time and because the other two parts don't need to move, but the table moves all the time and the rougher, slightly irregular ground off part is not ideal.
Possible solution 2: use a spindle sander to increase the ID of the hole in the table. Still take time, but less? Still going to be slightly irregular. Not rejected yet...
Possible solution 3: (need your help with this one) replace the table with inexpensive alternative. Needs to accommodate the full 1.75" column. The old one has manual adjustment, so a replacement might have a crank raise/lower function...
Thoughts?
Thoughts?
