I know I can buy a new one, but one that has a dual gauge, with multiple high and low outputs isn't cheap. And this one is already in place, so I don't have to mess with disconnecting any piping. Otherwise, I wouldn't have asked about fixing this one.
Anyway, here are some pictures. The first one is showing the entire thing mounted on the wall. I noticed the guages read ashcroft, so maybe not an older CH model? Almost looks like a Norgren style of cone. The second one is when I removed everything that was easily removable. The third shows the pieces in the order of removal, and the last picture is of the diaphram. The screw presses against the domed metal piece, to compress or release the spring. The spring then sits on the metal washer shape, the underside of which depresses the pin in the second photo, allowing pressure thru.
I did make sure I had the piping go thru the Low side (instead of the high side). It is not an instant pressure rise when I release the pressure down-range of the regulator, but rather a gradual gain. I would say it is about 30-45 seconds to go from 0-100psi from a 60 gal tank supply. Guessing something is causing the pin to not release fully, but unsure if I should be looking more at the pin itself (degreasing, etc) or the diaphram. Anyone removed the knurled part behind the regulator to get at the pin? Or ideas on what I should be looking at to fix/replace?
