Rebuilding pneumatic tools
RivennHewn
PNW
Any trick to rebuilding air tools?
Impact, drill, rivet guns?
I ended up with a rivet gun that leaks a lot of air. What's involved in repairing them?
Thanks for your time,
wafrederick
Holton,Mi
Price the parts first after finding out what is causing the problem and price the tool new.Sometimes it is cheaper to buy new instead of fixing it.
billymade
New Mexico
Depends on the rivet gun; the professional/industrial versions can be very expensive! In the case of these; they are worth repairing. The repairs/problems typically break down into:
1. head won't grip rivets: gripping jaws wear out, easy fix replace worn parts
2. gun body problems: o-rings/bladder/pneumatic portion needs refreshed; r/r new parts
3. hydraulic portion:r/r new parts and system bled with special tool or homemade tool. You might bleed the system first and then see how it works.
Here are some videos that give you a sense of repair/maintenance of the pro grade tools; these will probably be similar to the lower value ones as well:
more:
http://www.youtube.com/results?sear...0.0.140.140.0j1.1.0...0.0...1ac.2.trs6eo_NmNY
http://www.youtube.com/results?sear...3.0.143.359.1j2.3.0...0.0...1ac.1.4k1evjY97Yg
You might also check out a number of air tool repair centers online; one place that sells parts and service for the trailer repair industry is below. Good luck! :)
http://www.threedaytool.com/
Air tools in general are not that hard to repair; again, see how much the parts are and judge the cost effectiveness of the repair vs. new as mentioned above! Again, good luck! :)
Ben7203
Colbert, GA
Air tools are simple to work on, getting repair parts for off-shore brands may be the hardest part. Normal parts that wear out are bearings, o-rings, pulling jaws and air fins. A light with a magnifying glass comes in andy too. If you have any torque controlled tools, those can be a bear and will need to be calibrated. We have a simple work station at work that has all the parts and tool literature. 90% of the work can be done with simple hand tools and a vice. There are allot of smaller screws and bolts, so be careful and do not over torque anything.
R
RivennHewn
PNW
Thank you for the post.
The tool that's needing attention is a 4x by US Industrial Tool.
Chris_PT
Shreveport, Louisiana
I am particularly interested in this topic because I have a handful of air tools that are from my dads shop that could use service/rebuild. A few IR air ratchets, Matco Impact, and B&D 3/8" impact (love this little gun)-which actually works, but the ball detent that holds the socket in place is missing.
Not to hijack, but I (perhaps others) will find any information of good use.
Thanks in advance.
R
RivennHewn
PNW
There is a steady flow out of the exhaust ports, between the main body and the long nose piece.
up_in_the_air
Christchurch, New Zealand
Have you tried putting a rivet snap and retainer on and holding against a block of wood or something soft and pulling the trigger? Some guns will not operate with out being against a rivet
R
RivennHewn
PNW
It seems to operate as it should, just leaks mass air.
Maybe hits with less impact due to the loss of air.
BDT/NWMN
Erskine, Mn
Before doing anything else, uncouple the air hose, tie the trigger open with a piece of wire, and flood the tool with MMO or your favorite air tool oil.... Add oil when needed, and just let it sit and soak for a week or two... Then cover the tool with a cloth and couple on an air hose..
May be all that is needed if the tool has been stored or just gummed up...
R
RivennHewn
PNW
It's well oiled. The exhaust air has oil in it and it's coming out the business end too.
signcrafter
Sounds like it needs new orings. If it sat around for a while the orings will rot and deteriorate and leak. Take it apart and find the orings where its leaking and replace them.
John Timmins
Flagler Beach, FL
I just got a price for an Ingersol Rand 1/2 inch drive impact gun (40 years old ? ) and the rebuild kit was $75. Trying to find a kit for that serial number was hard so I finally sent an email to a tool place with parts and they sent me that quote. I don't know If i will rebuild it of not. The trigger stays down and it's weak. I'm sure the vanes are worn and probably the kit has bearings that are needed.
