Well, I finally got around to redoing my air system in the garage. All 1/2" copper to a coalescer, dual filters, regulator and up to a reel and a drop for my milling machine. The milling machine uses a air assist on the knee to make it easier to lift the 11" x 58" table. It is a beast of a turret mill.
Pictures in order left to right: (click to enlarge)
1, the compressor.
2. I ran a hose bent back to the wall to provide vibration relief and proper drip angles. I used 1/2" goodyear rubber for this. where the pipe starts at the wall is 3 inches higher than where it ends 25 ft away at the regulator filters to provie a downward slope for drraining.
3. Overview of the filter setup. The wire is the power cord for the compressor. I have to plug it in due to having only one 220 v outlet out there. Gotta share. The vertical section also acts as a drip leg with a automatic drain at the bottom and a ball valve to service it.
4. From left to right: ball valve shutoff. -- Coalescing filter -- 5 micron particulate filter -- .5 micron oil filter -- regulator -- utility connector hi flow -- riser leg out -- ball valve for bleeding air out of secondary system -- very short drop with a 45 on it to disperse the bleed off air. (Wilkerson F18-04-SK00 and M18-04-BK00 filters)
5. Left hand view
6. Right hand view
7, Feed riser pipe
1, the compressor.
5. Left hand view
6. Right hand view
7, Feed riser pipe
