Receiver Hitch Pin Hole Repair
PassnThru
Bowling Green KY
I've towed with a Chevy, Toyota, and Ford. They all had a somewhat sloppy hitch. Maybe this one was worse but a little clunk was always part of the game. At what point does the clunk become excessive?
NUTTSGT
Northern Central Ohio
When the safety chains get tight ! :lol_hitti
Honestly, this is a smart idea and would probably help out those that tow all the time.
ForceFed70
BC, Canada
You should start selling the bushings. Most of us dont have the equipment to make them ourselves and I would certainly buy a set if I needed to do this kind of repair.
rpmgroup
i drilled a 5/8 hole on the bottom of the tube and welded a 1/2 nut over the hole. after i install my receiver i run a 1/2 bolt up against the receiver and use a jam nut to secure it. no up and down, or back and forth movement.
Ign
Butte Peak ND
I don't see this as a good idea for any appreciable tongue weight. If anything you want the draw bar DOWN in the hitch, ie the direction in which gravity and tongue weight want to pull it.
If you push the draw bar UP with a bolt it's going to try to pivot on that bolt.
Ign
Butte Peak ND
Also I've considered a very similar repair on my tractor's blade. It's just a manual adjust for the angle and of course the holes that are used the most are severely wallowed - plus the pin is only in single shear in this application.
I was thinking of making bushings from 304 stainless as I have a ton of it in solid round stock. I'd think this would be an excellent choice as stainless is so tough. Of course it's not ideal to weld it to black but on bushings like this the welds are not that critical.
