Conductor562
I recently bought a new house and since the previous owner decided to paint all the outlets and switches the same funky *** colors as the walls (4 rooms were pink), I have to replace them all. I have 2 questions:
1. Is there any real advantage to the push in installation as opposed to loops?
2. I've noticed that every outlet has wires crossed.
Example: Wire coming in from left has its hot wire attached to the top of the outlet, but the neutral from the same wire is attached to the bottom. Each end of the outlet is wired with one wire from the wire coming in and one wire from the one going out.
Is there a purpose for this? Does it matter if the top poles are both hooked to the wire coming in while the bottom poles are hooked to the one going out?
