Recessed Garage Lighting
metaj
I was set on getting 4 foot fixtures and Hyperikon LED tubes, but then I started thinking about recessed lighting and I kinda like the idea better. I'll mainly be detailing in the garage so it is important. Has anybody installed recessed lighting in their garage and what kind did you use? Any information would be helpful!
LX-Markham
Markham, Ont.
I used 4' troffers: Lithonia GT8 1'x4', with a pair of 4' T8's in each fixture.
PhantomEB
Medicine Hat, AB, Canuckistan
9'6" ceiling, 9'door.....damn rights I used recessed troffer lights.
Lithonia 4' 4 bulbs stuffed with t5ho bulbs. Left the covers off them. Bright as hell out there with all lights turned on. Even require shades at times!
BreeStephany
Oregon
I did can lights in my shop when I insulated and sheetrocked it. Over work benches and primary work areas, I installed 6" Halo cans with simple white trims every 24" in a straight line over the work area and then put cans 6' O.C. in every direction everywhere else.
The shop has 10' ceilings and it provides plenty of light throughout the shop.
prostreetamx
Las Vegas
It also depends if it is an attached garage with a fire rated ceiling. Where I live you can not install can lights in a garage ceiling if you have living space above unless you build a sheetrock box around each one in the attic. The ceiling in my new garage does not meet that criteria but I did not want to penetrate the lid with holes that let the heat and cold pass through the cans. You normally can not insulate tightly around cans unless they are rated for direct contact with insulation.
PhysicsDude
Dallas, TX
Cans inherently cast a lot more shadows than tube fixtures. You either need 12'+ high ceilings or to put cans every 4 feet for it to work well. If you're doing car detailing I would particularly encourage you to put in standard tube fixtures rather than cans.
Ch3No2
I walked in to a buddies garage and noticed how smooth the ceiling was with recessed lights and I made my mind up right there. I went with 4 tube dual ballasts so I could either have 2 or 4 lights on per fixture with 2 switches. I also put the center row on separate switches from the outer rows so bottom line with the 4 switches I can have 10, 20, 40 or all 60 tubes on at any time.
Schumi
Kansas City, MO USA
What light fixture did you use?
Lelandwelds
Central Texas
What are the two doorways? Just house access? Or, something interesting like a tool crib, grinding or welding room ?
Lelandwelds
Central Texas
I would go with your 4 ft LED idea. Fewer fixtures and more even lighting. 40% less electricity. Seven to 25 years without changing bulbs. Read the stickies for fixture and layout recomendations. ( They're updated often so the old posts are actually the current ones.)
There is one close to your garage.
Ch3No2
It is a detached garage and the larger opening leads to an engine assembly room and the man door is the entry door.
PortDI064
Your light for garage ceiling is pretty impressive. Is it LED light? Besides, I would like to have a reply to OP. Having the recessed light for garage ceiling seems a good idea because of its better appearance. However, we also need to tackle the heat issue of the LED lights. To much heat accumulation on the ceiling will damage the LED garage lights.
Ak Jim
Interior AK
In one portion of my garage addition (15'x28') I used 20 can lights. I used 900 lumen 4000k LEDs in the cans. The walls are painted with Sherwin Williams high reflective white and the walls are smooth, no texture. The floor is epoxy with mostly white and light gray flakes. The lighting is outstanding! Virtually no shadows and very bright. I just got done doing tierod ends, wheel bearings, brakes, and a power steering pump on a car and I didn't need any additional lights.
