Recessed hex head clearance question.
Stedlin
Duluth, MN
Is there a standard for recessed hex head screw counterbore clearance for sockets?
In other words the difference between the socket OD and the counterbore ID.
rlitman
Long Island
I wish. Every manufacturer has different socket wall thickness dimensions, with the thinner ones being universally more expensive.
The first way I read your post, I thought you were talking about recessed hex cap screws, which of course have standard head sizes and counterbores, but sockets don't come into play.
PCustoms
VT
I don't think I've ever seen a recessed hex head.
If you are designing something, use a shcs.
Stedlin
Duluth, MN
Thanks for the replies.
I have seen recessed hex heads. Once in a air compressor head for example.
It’s not just counterbores but clearance that I’m wondering about. An example would be a hex head that is adjacent to a feature that could cause interference with the socket.
alex71
SE Florida
gotcha. There's no standard, because there is no standard for socket wall thickness. If I was doing this I would try to be conservative and allow for as much space as possible around the head of the fastener...
Stedlin
Duluth, MN
My current design is a 1/16” larger in OD than a Proto. Unfortunately I have no way of knowing if this will be an issue.
alex71
SE Florida
i would think using a cheap import impact socket as your guide would cover you. those are normally thicker than good ones, and certainly thicker than any chrome socket
rlitman
Long Island
Impact sockets do always have thicker walls than chrome, with the cheapest ones usually being the thickest.
AdAstra
There are certainly industry standards for max OD of a socket.
ASME B107:110 is one that most US-sold tools would adhere to.
ISO 2725-1 covers metric sockets.
Machinery's Handbook also lists wrench and socket clearances.
Stedlin
Duluth, MN
I seem to have misplaced my copy of the Machinery's handbook 16th edition that I got new in 1972. I'm sure it's around here somewhere unless of course I let someone borrow it.
I have been able to revise my design and make it work within the specification so I'm very excited about that.
Thanks for all the help guys.
PCustoms
VT
I've been involved with a few parts over the years where the designer should have borrowed a copy.
Hope you find yours!
AdAstra
Here's the relevant page from the 26th Edition, which doesn't tabulate metric clearances, but they are easy enough to figure out from the socket max ODs posted previously, looks like the latest edition has it, they add about 1.5 mm to the socket max OD.
Stedlin
Duluth, MN
Referring to this ASME spec:
The very first size I examined has a discrepancy.
11 mm and 7/16 only differ by .0045” yet the max diameter nut end is .683” for the 7/16” and 16.75mm (.659”) for the 11 mm.
.024” difference?
AdAstra
These are generally voluntary industry consensus specs drafted by committee, codifying products that were already in production. It’s possible some old tool company had long been making its inch sockets to that large size, and the spec might have been written reflect that. Hard to know, but one possibility. For instance you can see this as an artifact on the drive end max diameters, where they probably polled companies who used the same pre-broach blank for various sizes, and used the largest.
Stedlin
Duluth, MN
It seems that the OD specs for sockets are much tighter for hex screws in counterbores. If there are no recessed hex screws than the sockets can be quite a bit larger.
The only hex head screws I recall seeing in a counterbore was on an air compressor so I don’t think it’s very common.
Wolley
Maine
I have seen hex flange head bolts in a counterbore. On the spindle to hub bolts on 2500 gm trucks
Junkdrawer Dog
LV NV
Machinery's handbook has standards for wrench clearances. At least the older ones that I have do.
lg
no neat sig line
Haha! Machinery's Handbook! I used to hate lugging that thing to college classes in machine design and drafting. Now, some forty odd years later, I'm thinking about acquiring another copy for a little light reading at bedtime!
