Reciprocating Saw and PVC Pipe
Wamsutta
Amarillo, Texas
Is there any possible way to cut PVC pipe square with a reciprocating saw, or is a miter saw the only way to do it?
PugetDude
Superstition Mountains, AZ
Wrap 2" wide masking tape around the pipe, making sure it lines up to mark a square cut. Use a fine tooth blade, shorter than the diameter of the pipe. Cut slowly, make sure the pipe is clamped securely to prevent it from grabbing. You can cut right up to the masking tape with this method. Ideally, you're just barely nudging the tape with the sawblade.
(or just use a sharp Japanese handsaw...)
ReggieR
Vinton
HUH ? That lil ****. Use a diamond wheel in an angle grinder. You know...the sectored ones they claim to be the ultimate for steel , ceramic, gouda cheeses etc. They whack PVC faster thannnnn...... just toss one in the angle grinder and get after it
PugetDude
I can cut a piece of 1" PVC faster with a "lil ****" bearsaw than you can drag out the grinder and extension cord...with a fraction of the mess.
To each his own.
Marctrees
TX/LA border - Toledo Bend
To each his own.
I think he meant the OP's 1" pipe size was lil ****, not the Bear saw.
Keep in mind some of these guys work w like 12" PVC pipe for utilitys, etc.. so 1" is baby stuff.
Marc
Captain Spaulding
Southern Indiana
I had to cut a bunch of short sections of 6" for some fixtures at work. They had to be square to work. I hose clamped the recip to a 2x4 and pinned the 2x4 with a bolt to a bench so the recip could swing up and down on the 2x4 arm. I screwed two 2X6s together edge to edge to make an L-shaped trough and clamped it to saw horses with the opening up.
I could lift the recip up, slide the pipe in the trough, then lower the recip blade onto the pipe. I hoped it would cut square by itself, but it turned out the blade flex was enough to screw up my cut so I had to slow the recip down and rotate the pipe while cutting to get good square cuts.
Took me about 15 minutes to knock it together with a bunch of ratchet straps, cable ties and some screws. I made about 300 cuts with it that way.
WWheeler
Middleofnowhere USA
lol, fwiw that's exactly what I bought that jig for, well, sort of. We used a diamond blade for cutting a hundred or more pieces of ~3/4" acrylic tube which we had to be really picky about a clean end and the length.
Mentioned it here before. Worked like a champ, and have left the grinder in it ever since, though now mostly sports an abrasive blade for use as a general purpose mini-chop saw.
sberry
Brethren, Michigan
I can use a recipt saw. I use a coarse metal blade and can eyeball it and do them regular enough to be near perfect or close enough for general plumbing work. A lot of times I really rotate it about 1/4 turn to make it line up.
icthruu74
I’d use a miter saw, but that’s because I have it set up and it would take less time than dragging out the recip and cords. Other than a hacksaw and drywall saw I don’t even have a handsaw anymore.
W
Wamsutta
Amarillo, Texas
I use a set of saw guides for cutting stainless pipe in the field. They are hardened stainless and have 2 slots, one for a portaband and one for a sawzall.
http://www.techsouthinc.com/pipeclamps/sawguides.html
Downsides are cost and size availability. They are about $100 each and are only really useful up to about 4" or so.
Gee what a coincidence! I found that video after doing a Google search a little while ago. I should have read your post before calling the pipe supply.
Yarpo
Minnesota
I dunno what you're doing with your pipe or what your project entails but I still think you should get a miter saw if you're doing any large projects. Ratchet cutter for a small project. That said you can cut it with just about anything and getting close to square is often good enough. If you spent the same amount of time plumbing as you've spent searching for a tool to cut square, you'd have a full house roughed in :thumbup:
Yarpo
Minnesota
They are not known for cutting pipe square unless you know of one that can?
Are you doing plumbing in some sort of rocket science field or just looking to make things more complicated than they need be? :headscrat
There's a reason plumbers carry ratcheting cutters, they cut square enough if you start your cut square...
Eric29
Western NY
Milwaukee used to make an attachment for their sawzall that clamped on to a pipe and cut it straight. I always thought it would be helpful for cutting metal pipe, but I never bought one, and I’m not sure that the attachment is still around. If you could find one, I assume there would be no reason why you couldn’t use it on PVC pipe.
the gypsy
Montreal, Quebec, Canada
Hi Eric29. The tool you are referring to which holds the portaband is still advertised but it is outrageously expensive. There are cheaper alternatives, which I can't find in my pics now that I need them. but will post as soon as I find them.
metaldad
nw indiana
Gummi Bear
Sunset, Texas
Another vote for some ratcheting PVC cutters.
Mine are Ridgid brand, I bought them 20+ years ago when I started in the electrical trade. They cut up to 1-¼” in just a few strokes.
They look like this
I went to the woods because I wished to live deliberately...
Henry David Thoreau
Milton Shaw
One or two cuts, You could use the wire saw, it would take a lot less than a minute to cut through that. It probably would take less time than getting an extension cord and finding an outlet. Three or four back and fourths and its through.
59 wagon man
hollywood fla
i use my 25 year old Milwaukee 14" chop saw on up to 4". quick and simple and then i let the blade run and bevel the edge of the pvc. also have the Milwaukee cordless pvc cutter it works but the cut can be crooked
cheechi
Triad, NC
for one cut i clamp the pipe in the jawhorse and guide the shoe of the saw against the edge of the jawhorse vise.
for more than one cut the miter saw or the table saw sled whichever is more convenient.
