BigRed390
I'm mid-way through a drill press restoration and the bearings in the motor need to be replaced. What's your general recommendation on a bearing puller? I'm looking for more machinery-oriented applications than automotive-specific ones.
Is the HF stuff ok for this, or is this somethig I need to chase down a truck for? Do you prefer the 3-jaw gear puller approach, or do you like the kind with the bearing splitter that goes behind the bearing? Anything else I should know/watch out for?
Also, for re-installation, do you have to have a press? I've seen a few done here and there by putting the shaft in the freezer and heating the bearings. They seem to slip right on without too much trouble if you're fast, but I'm bound to run into something that won't fit in the freezer eventually, so what's your general consensus here? Is a hydraulic press helpful/necessary? Will a manual arbor press work for most of what I need?
I've got the old machinery bug fairly bad, so I don't mind springing for quality if there really is a difference, but I'm ok with a harbor freight answer too.
Thanks!
Thanks!
