texasdiver
Hi everyone.
I have a small repair project I need to do on a boat trailer that requires a couple of welds. Because I already have the trailer torn apart (with the boat on it) I can't haul it to a shop where I can use a regular 220 volt welder. I ruined a stuck bolt on the rear spring hanger and I have to cut it off and weld on a replacement.
The sailing club where I currently have the boat and trailer has 120 volt outlets in the clubhouse about 100 feet away so I can roll out about 100 ft of extension cords and plug into an old 120 volt outlet that is probably on a 15 or 20 amp breaker (not actually sure about that). And that is the best I can do.
Any recommendations for a small portable welder that can accomplish the job under those conditions? I just gotta make the one weld and then I'll basically put it away in the garage for any future welding jobs I might have which are not likely to be very often.
I thought about using a bolt-on spring hanger but the trailer rail is actually too narrow to use with the typical bolt-on hangers.
