Recommend a cut-off tool!
Moose-LandTran
The Brink of Insanity (England)
Hey, folks,
I want to buy a little air cut-off tool, useful for rusty exhaust bolts and all kinds of stuff, but am unsure which to buy. There's loads of cheap ones out there, but i don't want something that's going to die the second time i use it.
A co-worker has a Blue-Point (rebranded Campbell-Hausfeld?) one which seems very good, i bid on one on eBay but missed out on it.
Here's the one i'm looking at, Campbell-Hausfeld TL1135:
http://www.chpower.com/webapp/wcs/stores/servlet/chPrd3_10051_10001_96643_-1_10676_10711_
Any thoughts on this, or other recommendations? Don't want to spend loads on something i won't use that much, but also want something that won't die from my relatively light use. Suggested retail for the TL1135 is only $35.
Thanks!
Homespun91
Peoria, IL (more or less)
Truthfully...I have a cheap HF one that's lasted for years...replaced an IR which died after 3-4 years at most. I think I paid $9.99 for the HF one on a weekend when I was desperate, and haven't killed it yet....though I try. :)
Trucky
Altec
SoCo, MD
I use a blue point one. The rubber grip has long fallen off, but it still works great.
I don't think the HF models are a bad idea though.
mrbreezeet1
Moundsville, WV, 15 miles South Of Wheeling WV
rockchucker
Seattle WA
I am still using mine and I use it weekly. I think it is the Central Pneumatic 47077.
Here...
http://www.harborfreight.com/3-inch-high-speed-air-cutter-47077.html
Works great! I use Marvel Mystery Oil on all of my Air Tools and Oil them with 5 drops before use, if using them even for a second.
Moose-LandTran
I'm happy to pay $50-60, it really isn't something i'll use a whole lot. But i would like to have a "nice" one. That Campbell-Hausfeld is a nice looking tool too, and a good price.
Is it possible to somehow attach a wire wheel to one, for surface rust removal from bolt threads? Or will 20,000rpm cause it to explode and make me look like a porkupine?
Thanks for the input guys, looking into those suggested. :)
Trucky
I was snooping around the Dynabrade website and I saw a lot of different kind of wheels and whatnot there. Honestly, I'd give them a call and ask the experts. I wouldn't think it would be a good idea, but I only have experience with bolted down grinders and whatnot (Which I've seen plenty of wire wheels go crazy on..), so I can't give you any direct advice.
Racr350
Rochester, NY
I have the MAC with the articulating head. Soo nice to get different angles on things. Expensive..but a joy to use when you do this for a living. If price is a big factor, I wouldn't be afraid to get the nicer HF model
MAC:
http://www.mactools.com/Product/tabid/120/productid/318374/variantid/309133/Default.aspx
Harbor Freight:
http://www.harborfreight.com/air-tools/specialty-air-tools/3-inch-composite-air-cut-off-tool-95028.html
And I'm considering getting this for hard to reach places:
http://www.harborfreight.com/air-tools/specialty-air-tools/3-extended-reach-air-cutoff-tool-67996.html
rockchucker
Seattle WA
I have a small Die Grinder for the use of Wire Wheels. Same Central Pneumatic brand from HF. I Like to keep the Cut-off Wheels in the Cut-off so I don't have to remove the guard every time I want to Wire Wheel something. I also never have the need to run the Die Grinder at full speed with a Wire Wheel. I however do not buy cheap *** Wire Wheels for fear of them coming apart. I go to the real Tool Store and spend more money on a few wheels than I spent on the Tool from HF. I have always envisioned the Porcupine aftermath and don't want to be a pincushion when a cheap Wire Wheel lets go.
silversix
Los Angeles
I tried a Husky and a craftsman and was very disappointed, they had very little torque and would stop if I applied too much pressure. I bought a HF one and it is awesome! Had it for a few years now and it works great, very powerful.
Racr350
Rochester, NY
same here.. wire wheels are meant to be used on a die grinder. and they work great when you use decent ones.
wafrederick
Holton,Mi
Also come in reversable changing the shaft rotation,Mac and Matco make them.Body shops use this version to keep sparks away from the user.
Jdubzz
I have a Matco - the nice thing is the tool is reversible so the sparks fly the direction that you want them to.
crewchief888
NW indiana
i have several die grinders, the best of the bunch have been astro brand.
i needed a dedicated cutoff tool, bought the $10 HF, and have no complaints.
most wire brushes will disintegrate on a die grinder at full speed.
we used to get encapsulated brushes for die grinder use
worked out good for cleaning liner oring grooves in engine blocks
:beer:
91bronc300
Get this.
http://www.amazon.com/dp/B001ASC73E/?tag=atomicindus08-20
It's got cojones. It's more ergonomic than an air die grinder. And it's much, MUCH quieter. I've got one and I've got the HF air cut off tool. And I (practically) never grab the air one. Only if I have the air hose right handy and I would have to grab an extension cord to use the Makita do I ever use the air over the electric.
The HF cut off tool is pretty good for 10 or 12 bucks or whatever I paid for it. My compressor will run it full bore non stop and it does have power, like I say, it's a decent cut off tool. It's mostly other reasons I prefer the Makita.
For one, noise. I hate using any air tool more than 60 seconds at a time. And sometimes I need to use a die grinder for 10 or 15 minutes straight or more.
For two, ergonomics. I don't like having my hand so close to the working head of the tool. Often times it makes it harder to get the tool head where it needs to be because your bulky hand grabbing the bulky tool body is right in the way or too big to fit into a certain space. The fact that the electric has a long body is doubly handy because you extend the reach of the tool, plus you can put two hands on the tool when you need to be extra dextrous with it, doing very fine movements. Anyway, since I have both and I vastly prefer the electric die grinder for both burrs and stones AND cut off wheels I thought I'd chime in.
Get one, then go to HF and get this for 3 bucks
http://www.harborfreight.com/1-4-quarter-inch-cut-off-wheel-arbor-for-die-grinder-93389.html
evintho
Santa Rosa, CA.
Can't beat the HF Central Pneumatic cutoff tool. I paid $10 for mine 20 years ago and it's still going strong! Right now I'm using it daily 'cause I'm making patch panels for the roadster. Just keep it lubed! It's not so much the tool, it's the consumables that add up. A 5-pack of the good 3M cutoff wheels are $20+!
kartracer55
The Harbor Freight one is OK. Mine sees intermittent use around the house and has been going for a year or two now. I purchased another one for the shop and guys use it probably daily, never oil it etc etc.
I will say this. It works fine, but it doesn't have the power of a higher end one and it probably uses as much, if not more air. Air tools are one area where higher quality (dont confuse with price) can pay off for power/consumption.
I think the Chicago Pneumatic 861 is a significantly better tool, with far more resistance to stall, and the ones I have seen were made in Japan and had been around the block. Certainly one of my favorites, however it also costs way more. The HF is a much better VALUE, but an inferior tool to the CP861 @ $115 vs ~$10
yogitech
Orlando, FL
Moose, i've got two of the HF ones and used them constantly for the past 5 yrs w/ zero issues. Couldn't justify the cost for the Name brands for the purpose of the tool. Do you have HF in London?
RKA
+1 for the HF. I'm more than happy to spend the money on a quality tool. But for me, this is something that sits in the toolbox "just in case". I've pulled it out once in the last year, so I'm more than happy to have saved the money here so I could splurge on other things.
Yotaforce
Western NC Mountains
I only buy the $9.99 at Harbor Freight. They usually last me a few years (and I use the **** out of them restoring cars for a living), and when they break, which they always do, I throw it away (after removing the wheel) and go pick up another.
I have worked at places that bought the high dollar ones. They would break just as easy, but then the boss would cry and whine about how much it's gonna cost to replace it, and usually yell at whoever used it last and try to blame them. Lol.
Honda guy
North Carolina
MAC:
Harbor Freight:
+1 on the Mac. The flex-head feature comes in handy sometimes. Good power. Rubber coated body keeps it from getting too cold to handle, if you use it for extended periods. You can get just the tool, without the box etc. , for about $240.
evan71
NUTTSGT
Northern Central Ohio
I bought my Campbell-Hausfield at TSC about 6 years ago, never had a problem with it. I took the lawyer guard off of it. If you leave it on, you'll never get it into a tight space on a car.
vssjim
McLean Va.
I have had a Florida Pneumatic cut off tool for over 20 years and it is fairly strong and has been trouble free.
Kev442
Wi
Have several of the cheap HF's. I just upgraded to the FP linked to at Amazon as the HF's like to stall out and get cold with extended use. If you are not doing extensive metalwork on cars, the HF is fine, especially on sale for $6.99. I still use the HF's a lot yet.
garfunkle24
Saskatoon, Canada
I have the flex head Mac one too, but IMHO it is over-priced, overweight, too fat and limited in it's utility. The thing is so cumbersome that to me it pretty much negates the benefit of the flex head. Each to their own I guess.
I prefer a regular die grinder over a cut-off tool anyway as the guard pisses me off.
Skin
Boston
Hey, folks,
Thanks!
I've had that CH [or a very similar model anyway] for about 2 years, its cut hundreds of rusted nuts and bolts and is still fine. I abuse cheap air tools as well, its probably seen about a dozen drops of mystery oil in its whole life. My one and only minor complaint is the shield doesnt lock, it ratchets. Other than that its light, nothings broken, and it does its job.
Hammer1963
Kentucky
If you really want a good cut-off tool. spring for the Matco reversible cut-off tool. I have been using pnuematic cut-off tools for 30 years and this is the best I have ever used. This is one bad *** tool. I also have a new Snap-on cut-off tool that I strictly use for grinding welds. It too is a good tool, but it's not nearly as powerful as the Matco unit
CommonRail
X2 on the indexable MAC. Worth every penny. I also have the extended version MAC whick is very handy in tight situations.
Moose-LandTran
Thanks for the recommendations, guys. As temping as some of the suggestions are, many are waaay out of my price range. Found a new CH one like in my first post for a wallet-pleasing $13.69, new off eBay!
I think i'll just wait until i buy an electric angle grinder and put a wire wheel on that, don't need wires flying into my skin from too high rpm.
I didn't want to spend a lot right now, and the big name brands are far too much money for the little use this will see. I wanted something cheap but not unbranded and generic. Imported is fine.
No, we don't.
Good to know. I'll leave the guard on, save me from sparks flying in my face.
That's good. I oil my air tools every time i use them, so hopefully should last the same.
