Recommend a good brazing, spot weld, etc. torch kit?
Mr. Tool
Looking for recommendations on a smaller kit that is good to use for brazing, spot weld, etc. that is "IF" there is one that even exist?
Something other than this Bernzomatic one (click on link below) that has terrible reviews:
As I understand it, from reading reviews and all, etc. the Bernzomatic kit, the Oxygen tank seems to run out very rapidly when in use?
Anyway, Thanks in advance to those who post.
slowtwitch73
Hellgate
Spot welding is generally an electrical process. There are actual spot welders, but you can pull it off in a fashion with mig, tig etc.
The brazing depends on what you will be brazing and brazing with. That kit linked would run out real fast unless you were a jeweler or similar.... small things that heat easily and rod on the lower end of the temp spectrum.
For bigger stuff, look into an oxy acetylene setup.
Mr. Tool
Something more like this maybe? :dunno:
