Recommend a Quality Set Punches & Chisels
Elroy
kentucky
does elroy have any tips on how to produce such a nice clean striking end?
Well it helps tremendously to have one of these:
With non-loaded abrasive of course
Elroy
kentucky
The 25 cent Baltimore punch before
Same 25 cent Baltimore punch AFTER:
This transformation occurred in no more than 5 minutes
rodm1
OK, back on topic :D
Are the Snap-On / Matco branded Mayhew's "S-2" steel?
Anyone have any comments for or against the S-2 steel variety? The punches / chisels with the S-2 Steel are referred to as "S-Series"
S-7 would be a better choice they use it in die punches. S-2 is probable a good compromise on cost. Is it better then there standard model no idea.
http://www.sousacorp.com/tool1.htm
F
Flash21
Is this Snap On kit made by Mayhew?
No, I think the USA top shelf Matcos are made by Mayhew. However, as far as I know, Snap-On makes their own punch/chisels. I have carefully compared them and there are differences.
Steve_P
I have two sets of ~30 yr old starrett pin punches (in the wooden cylindrical container which is also cool) and they're fantastic. I bought a few new starrett singles from Amazon but noticed they are not marked USA.
Does anyone know where the newer Starrett punches are made?
I don't know if they're as good as the old ones as I haven't used them much, but the old ones are just about bombproof. Of course you can bend any thin punch. I also have starrett center punches (love them also), and PB Swiss and Mayhew pin punches. For chisels I have newer Mayhews, and some vintage Armstrong, all good.
JayL
Manila, Philippines
Would you mind sharing what you have found out please.
mofo62
Perù
Interesting information, through all the threads I could find I don't think I ran across that information...thanks Krusty.
So, it looks like Mayhew (sold as Matco, Snap-On), Martin (sold as Cornwell) are the leaders.
Anyone have any comments for or against the S-2 steel variety? These are referred to as "S-Series"
From their catalog: (This is from the catalog page for "The 150 Line)
"High grade S-2 Tool Steel for superior tensile strength, toughness & long life!"
"Full Shank heat treating!"
"Parabolic head to reduce mushrooming & chipping!"
"Black Oxide finish for enhanced corrosion resistance!"
"Full Professional Finish!"
The Advantages of Full Shank Heat Treating
Full shank heat treat is a two step process where the entire length of the too is hardened and tempered and then the struck end of the tool is drawn back.
Advantage: Struck end is less susceptible to mushroooming.
Much thabks for information :rocker:
Today buy my Prybar Wright ,but its made for MayHew (Its great .its strong ) Great Mayhew,my first tool Mayhew its 100happy.tomorrow pictures...:bounce::bowdown::)
nissan_crawler
Wichita, KS
I have Dasco, Craftsmen (whatever they are), Mayhew, and Snap-0n punches. I went through the dasco set at work, broke them, replaced them, got craftsman at work...broke those, took them home, got mayhew...broke/bent those, took them home, bit the bullet and bought snap-on ones well over a year ago. to date, I haven't bent or broken a single one of them.
Yes, there's a difference. A BIG one. What it is, I have no idea. They're the only ones that have held up for breaking rivet heads and pounding them out, though.
