Recommend air hammer chisels?
Bcom
Nebraska
I just picked up an Ingersoll Rand air hammer with quick change attachment second hand. Its in great shape but has no chisels. Ive never owned an air hammer before. Ive been told that the short chisels really **** and if you dont get a set of decent chisels,they will flatten quickly. Are the short chisels really that bad? This air hammer wont be used very often. Anyone recommend a small set of air chisels that wont break the bank? Hows the HF air chisels? They are like $5 a set. Any help?
G-Ram
NWO
If you want them to last, you're going to have to spend a bit of money. You definitely "get what you pay for" when it comes to air hammer chisels
Bcom
Nebraska
I agree with that but my hammer isnt going to be used all that often so i figure a cheaper chisel set would work fine
2ndGearRubber
Pittsburgh
Yep, if you have a hammer that really hits (like my CP), you will eventually shear the hammer receiving bit off.
I get the AJAX from HJE. Cheaper bits work alright with weaker hammers though.
JJThrasher
Indiana
I've dulled and broken pretty much every brand I've used. The cheap ones are fine if you have a bench grinder to resharpen and shape them. I have some SO ones that are decent. Luckily the warranty is good.
Mhyde52
Averill Park, NY
All of mine are Mac branded, with the exception of two Napa straight punches. The Mac ones seem to be good, especially for light to moderate use on a pretty hard hitting cp hammer.
Schurkey
I think my air hammer is a CP 7150, but if it is, it's earlier-production with black paint instead of CP Red like the web sites show. Burp-Guns only become useful once you have a hammer bit (chisel) suitable for the work you're doing. There's fifty+ different styles of hammer bits to choose from.
While I prefer the longer ones, I wound up with a short set of Old Forge (I think) bits which were made in USA. Bought 'em years ago. They've held up well. I have a couple of Snap-On exhaust pipe cutters, a Snappy suspension-joint picklefork that I don't use any more, and a few odds-and-ends. I bought my Zip-Gun to remove rivets holding ball joints to the control arms of my K1500. At the time, I had a 120-volt POS air compressor. Took me all day. You're going to figure out right away that you'd better have a REAL air compressor.
Best to figure out what you're likely to use it for, and then buy quality bits, than to buy some universal bit set where all the supplied bits don't serve any purpose for you. OTOH, the useless bits can give you some blacksmith practice as you heat them up and re-forge them into a useful shape.
2oolhound
BC Canada
Just be aware, when your bit is getting rounded off it's absorbing impact that was supposed to be thrown at the work. You are loosing efficiency and working harder.
