Recommend bore brushes
ecotec
Have you guys found that any brand of bore brushes, for use in an impact driver, works better than the other brands?
This would be, mostly, for cleaning out brake slider pin ports.
Obviously, they need to be the kind that work in 1/4” impact drivers.
mikey03
E
ecotec
Oh damn I didn’t know this was a thing. I used a paper towel wrapped around a straight pick to clean out the slider pin tube in brake calipers last time I did it. I’ll be ordering one of these soon!
I use paper towel (the blue shop kind) to clean out the boots, but I use a bore brush with a handle to clean out the slider ports.
I have been wanting to switch to bore brushes that go in an impact driver or drill.
mikey03
oh I just figure to replace the boots each time because their rubber and cheap. Brakes might go 5 to 10 years depending how much you drive and idk if a used piece of rubber going to make it another 10 years tbh
but maybe if you go that long between brake jobs maybe you should clean and relube the pins every few years? And you could see then if the boots need changing
E
ecotec
I always just reuse them, but I am careful not to get brake cleaner on them.
Nutria
Eastern Sierra
scooby074
Nova Scotia
Drill bit.
I also have a set made by Grip that has a screwdriver loke handle and hex drive brushes. Also rebranded by many other importers. Soso quality
If you can order something from Osborne or weider or Walter that will work it would be much higher quality
charbar
Midwest
Piece of rod with a slit cut in the end so you can stick emery cloth in it and do a wrap or two around the rod. Stick it in the drill and go to town. Way quicker and more effective than a brush.
rust in the eye
Chicagoland
I bought a smaller set of what looks to be the identical brushes in a blister pack from hobo frt for only a few bucks.
I consider the brushes disposable, the 1/4" hex drive extension that comes with them is handy for other uses.
Steve_P
I have the generic set pictured above. For the $ it's OK, but the steel brushes do not last long, at all, for me. One or two uses and they're shot.
Buster21
Idaho
Same set as above, I have only used the nylon ones. Noticed this set with a handle at Harbor Freight yesterday.
