Recommend me a good Cordless Screwdriver
Bubba Fett
Eastern NC
Alright y'all. I need some recommendations!
I need a cordless driver that can accept any power bit, and maybe insert bits with or without a bit holder (though that isn't critical).
Needs to be pretty small and lightweight so I can use it in confined areas. Multiple people will be using it, so one that can be used in either hand would be best.
It will be used mostly for installing servers, networking equipment, audio/visual equipment, cable management, assembling utility carts, mounting things like TVs, Projectors, Security Cameras, Access Points, Speakers, etc. Could be used to assemble furniture, workbenches, or whatever, so variable torque and speed settings would be a plus.
I already have a hammer drill, so it won't really be needed for making holes.
Not sure if I want one that can go from strait-handled to pistol handle, or if I should go with a small pistol-grip, or even an impact driver. I do want one that allows batteries to be swapped, comes with 2 batteries, and a charger.
I don't really have a brand preference (we have Red, Blue, Teal, and Yellow/Black), but it needs to be reliable.
It has to come from Grainger, Global Supply, or other industrial suppliers, not the typical retail chains. Price needs to be decent, and probably no more than $500 or so for everything. (Although that isn't critical.)
I don't use cordless drivers much, because I prefer manual drivers, but I often deal with long machine screws, which can get tiring.
What do you use/recommend?
loganb
Omaha, NE
For what you're describing, my go to for that type of work is this:
Very compact and easy to maneuver, versatile, M12 battery platform....hard to go wrong
mike93lx
Richmond, VA
Beat me to it. Feels like a great fit for the application.
Only problem is keeping it organized. I highly recommend getting a small packout case and inserts designed by Jonah Pope. No affiliation, just a really happy customer
sparky 1971
Central Iowa
This is one of my most used tools. Small, lightweight, variable speed from slow to really fast (2450rpm), can be used with either hand, and doesn't have enough power to mangle screws but will run a drywall screw into a 2X4 given enough time, but that's not what it's made for.
And, it's available from Grainger
I have the Milwaukee M4 and have had other brands, They are all slow (400 rpm tops) and have no power at all.
I like this for an extension of a manual screwdriver. Not tons of torque, so it gets used for stuff I don’t want to foul up. Mine is a -1
Great for homeowner grade stuff, not sure about server grade 2” screws.
mike93lx
Richmond, VA
What do y'all think of the Milwaukee 2401-22?
I'm sure it works fine.
The installation driver has 4 different chucks, making it super versatile. I imagine the offset one could come in handy, plus the regular drill chuck would allow using standard drill bits
sparky 1971
Central Iowa
I have one. It's way too slow so I leave it in the house and let the wife use it.
Milwaukee makes/made another version with two speeds that is a little better, but not a game changer. I had one of those, but eight years ago my service truck was broken into and it was stolen. It was one of the few tools I didn't feel that was necessary to replace since I rarely used it. It's really nothing more than a drill with a quick lock in place of a chuck.
dscheidt
I have one, which I bought several years ago on sale on a lark. I expected it would end up unused, or given to the kid, but I use it a lot.
I keep it attached the leg of my workbench, and use it all the time to take stuff apart and put it back together. it's great for electrical devices and flat pack assembly. It's got plenty of power, but as @sparky 1971 says, it's slow. 600 rpm max, so a 2" 32 tpi screw takes 10 seconds or so. It's still faster than a manual screwdriver, but if I were a professional trimming out a house, I wouldn't use it because of the speed. The installation driver above is a much better choice for that.
dnschmidt
Phoenix, AZ
I've got them all but need more information to determine the right tool for the job. If you're working on delicate stuff the M4 is the way to go. For bigger stuff the 2401 works well and is what I use to take the under car covers off of my Toyota when I do an oil change. If speed is an issue a normal compact electric drill - I use the Milwaukee 3601 compact brushless drill is the way to go. The Makita impact driver referenced above is very nice for driving woodworking screws in a compact size. The Milwaukee installation tool, I think every manufacturer has a version of this now, is handy. More specific information is needed. Based on what you said I'd go with the Milwaukee compact drill. I bought mine for $99 for the complete kit during the Christmas season from Northern Tool.
Bubba Fett
Eastern NC
Interesting. So the 2401-22 is pretty slow, but that isn't necessarily a bad thing, since this will be used for delicate items.
I may have to get more than one model. A separate impact driver for heavier jobs might be ticket.
mike93lx
Richmond, VA
What kind of stuff are you thinking of when you say heavier? The installation driver does fine with smaller screws, but I'd never use it to drive a lag or a bunch of decking/construction screws. It's also definitely the wrong thing to use for breaking loose stuck nuts and bolts.
moab11
Thunder Bay, Ontario
I have a bunch of the m12 screwdrivers, and they are by far my most used tool, especially for screws and such.
I've used them for server racks, ikea furniture, removing some fence boards, etc. Easy to reign in the power, but can still do a fair bit if needed.
FTWingRiders
Central Ma
Well dang... here another tool I didn't know I needed and now must have!!
Thanks!:)
GeoBruin
I have the 2401-22 and the installation driver. In my case, they live in separate locations and serve separate purposes so it (kind of) makes sense, but in reality the the installation driver does everything the 2401-22 does, plus a whole lot more. The offset attachment is a godsend, the right angle attachment is also really nice to have sometimes, and the drill chuck is a nice little bonus. Note that the drill chuck can be used with the right angle attachment or the offset attachment as needed. The clutch has a ton of range from less than hand tight to driving screws, though it stops short of decking screws.
The only issue is the stupid reverse button is both a bad button and in a bad location. I'm only now starting to get used to and able to activate it without looking at it. But I'm sure it was a compromise to achieve the form factor.
mike93lx
Richmond, VA
I dont like that I can't pick it up and know which direction it's going to spin. Seems like a really odd decision to depart from a convention used on pretty much every other drill/driver. Having to reposition or use a second hand to change directions is annoying, as well.
Other than that, it's great! :)
WildBill
PNW
We use a bunch of the ‎2101-22 4v drivers at work, they are pretty decent and surprisingly powerful. I use one multiple times a day taking apart and repairing electronic test stations. Seems like it only needs charged about every three months.
308guru
I've had one of these for a long time and use it a lot. It's great. If I had a complaint I'd say it's a little heavier than I'd like but that's nitpicking.
vwpieces
Hills, PA
Huge fan of electric screw divers that resemble an actual screwdriver... I have a couple.
Wiha Zu Haus (china) hard to find. Had mine for about n10years and use it a lot. Realized they were getting even harder to find, I scored a backup off Amazon,de a couple years ago
Also have a couple HOTO boungt as Amazon returns, under $20ea.
No complaints.
And the latest is this Vessel clone ought on amazon for $10.70 No complaints
I have wrenched on them all pretty good but I am sure some Ape will break them. The china Wiha has survived me for over 10 years.
Yeah, not industrial suppliers but I would take my $11 AMIR to work on my own dime. Even if they supplied the tools.
Kscardsfan
The Little Apple
I found one of those on the road. I use it for stuff like chucking a brush up to clean the upholstery in the cars etc where I don’t want the impact etc.
AEAdam
SE PA
I just bought this thing and I really like it so far.
I don't have many 12V tools and I was worried about power and longevity. I have the regular battery and the bigger battery for this (with the square box on the end) and both have performed really well. This isn't even brushless.
Thought the trigger was fwd and reverse like Snap On's version. It's just on or off. But I'm okay with it. I use this for tight ares where I could be using it upside down, and in weird body positions to boot. So maybe this trigger is better for that.
The reverse button isn't amazingly convenient, but I don't really go back and forth. 90% of the time, its on fwd.
The head is very small and the small bits stick out only a little. If you can't fit this, get out a Sawzall because you really screwed up!
With a pistol grip tool, you kinda get some force behind the driver head, which I think is good. With this thing, you'd need 2 hands to do that, because the trigger is pretty low. So maybe not a perfect solution. But depending on the work and what people get used to, this could be perfect adequate.
Bubba Fett
Eastern NC
I was initially wanting one of the DeWalt Gyroscopic drivers, but Grainger said it's discontinued, which is strange. I've used one before and thought it was pretty neat. I wonder if DeWalt is about to release a new version, or if it will be re-branded as a Craftsman driver.
I do appreciate the suggestions and feedback.
LS1-IROC
Grand Rapids MI
The DeWalt Gyroscopic driver was a game changer for me. I have been using one for probably close to 10 years now at work. It gets used almost daily and is still kicking. The only complaint I have is that the LED light stopped working about 3 years ago. I hope they are not discontinuing it, I better buy a back-up unit if that's the case.
  • Like
Reactions: JBH
mike93lx
Richmond, VA
I remember something on this came up a year or so ago. At the time, Dewalt had stated that the 8v battery has been discontinued, which I expect means the tools are dead as well
They do have a non-gyroscopic 4v screwdriver out
richfinn
Leeds, Yorkshire, England
I nearly went with an M12 version (I already have some Milwaukee M12 tools)
At the last minute I decided to buy a Bosch GSR 12V-35 HX as it's way more compact. I love it 💗
acer66
Western North Carolina
People really buy and use these things? I've always thought they are sooooo weird and gimmicky.
I have the Bosch and somewhere an old Festool version of that and I really like it.
I mainly use it without the chuck for smaller size and weight.
But the right angle and offset are used on a somewhat regular bases too.
Odd-job
One powered screwdriver to rule them all doesn't quite exist. For the above range would get a Milwaukee 2406-20 two speed pistol grip and maybe this Vessel screwdriver for the smaller electronic stuff:
I also use M12 ratchets as glorified screwdrivers with a bit driver adapter way more than I would like to admit for getting at screws in tight spots.
m12 hydraulic surge for higher speed disassembly stuff.
Hopefully 3 out of 4 above suggestions would be less than $500 at Grainger jacked up pricing.
Bubba Fett
Eastern NC
I probably could go higher in price, but I also ordered a bunch of utility carts, a Little Giant ladder, and a bunch of other stuff, so I knew I was pressing my luck. LOL.
ipgenie
Idaho
I've got the Milwaukee above, the Dewalt gyroscopic and a few smaller ones. I have this one too and it might be the right fit for you :
It's fairly powerful for the size yet does well on delicate things too. My kit came with two batteries and the charger. I've used it for a bunch of things from roofing screws to drywall screws and server rack assembly.
Rinspeed
NY
I'm a huge Milwaukee fan but the Bosch 12V is a winner, I've bought four of them for the guys at the shop and they love them. The Dewalt gyroscopic is a joke as far as I'm concerned.
MiteyF
I have the dewalt, takes a little getting used to but works great for light duty stuff.
Boss at an old job had me pick out and order a new cordless screwdriver, and I bought that one (or perhaps an older version, it was a few years ago). I didn't know it was motion activated, and couldn't figure out why it only worked sometimes. After realizing how it worked, I had her return it immediately. I *hated* that thing.
Give me a trigger or a button, none of that gyro operated nonsense.
