Recommend me a grease gun
roosh725
Looking to replace the 5 grease guns I've gotten in the Past from HF. None of them work regularly. Not looking to spend a lot but il pay a little extra for one that works. Anyone have any that work? I've seen Lincoln has had good reviews.
autobon7
The Alemite 500 is a time proven gun. I prefer Alemite over Lincoln.
nfk
Kansas
I have used Alemine and Lincolns they both work fine, I usually grab whichever is handier.
R
roosh725
Is it worth getting a air powered one if I have an air compressor? Doesn't make that much of a difference it would be used maybe once a week or so
gte718p
I have the Craftsman Pro air powered one. It is a pain to get a new tube of grease started, but after that its great. Air power us much nicer then pumping when your upside down in small space under a piece of equipment. Of course normal people probably don't find themselves in that position very often, but for some reason everything I want to grease has fittings in the worst possible location. Just my 2 cents.
rlitman
Long Island
I have the same gun. I've got trouble keeping it primed, but I think that is more because of my choice of grease (Mobil 1; I'm NOT using this again once I use up my last tube).
Powered guns are better for when you have a hose on the gun. You can keep one hand on the chuck, and only need a finger to pump grease. Pistol grip guns were designed for this, but don't build the pressure you get out of a lever gun. Having power (whether it is air or battery) overcomes this issue.
The BEST thing I've done to my grease gun was to buy a Lock-N-Lube! It cost as much as the gun and was worth every penny.
bobcatdan
Kaukauna,WI
Alemite would be my first choice. Lincoln would be fine too. Legacy can burn in hell for all I care, utter junk. If greasing a lot, get a nice cordless one.
thebeekeeper1
Illinois
For the vast majority of applications it is definitely NOT good to have a pneumatic. They encourage over-greasing.
I bought a Lincoln pneumatic (Ebay--$60) due to having frequent use of an old farm disk that has a dozen hubs needing greased prior to every use. Three tubes of grease is a lot of hand squeezes to apply. I LOVE my pneumatic for that. :rocker:
R
roosh725
Lol I wish I could get that dewalt one! I ended up with the pneumatic craftsman one from sears for 34.99. Works great! Let's hope it lasts
GTL
Queensland, Australia
If you can find them in the States, Macnaught is an excellent brand of grease gun, I have several. They are made in Australia and you see them everywhere here.
kstools
+2
Macnaught. Depending on where you live, the only downside is they use bsp threads. Can make buying hoses, etc. a little bit of a hassle if you live where that is not a common thread type.
reader2580
Minneapolis, MN
I bought a Macnaught and it works quite well so far. Not cheap, but it is made in a first world country. The only thing I have that needs grease is my riding mower so it doesn't get used a whole lot so far.
