Recommend me a miter saw stand
Sh40674
Iowa
Looking for a new miter saw stand, and can't afford the bosch (that's the cats meow as far as I'm concerned).. I was going to go with the dewalt one with the wheels on the floor, but it gets bad reviews with its cable system getting stuck. Would like to store my 10" dewalt slider on it on its side so needs to be sturdy, have wheels on the floor on one side when set up, and easily collapsed and raised. How are the rigid brand? Delta? I'd like to stay around $225 or less. Thanks!
shawhite
The Bosch is the best in my opinion and worth the $. The delta and metabo will get the job done.
WWheeler
Middleofnowhere USA
I have had my Dewalt DWS779 on a Ridgid AC9946 for a couple years now and have zero complaints so far. I really like it and how easy it is to set up. I originally wanted the Dewalt and only got the Ridgid because the Dewalt wasn't in stock anywhere locally at the time when I needed it. Since then I have had the chance to use the Dewalt and compare and it worked fine BUT the friend who owns it did say he had to have the shock or whatever it is replaced because it had failed. I didn't ask but I think it was probably a warranty thing as his is a lot newer than mine, but now I think I kind of prefer the Ridgid's design.
All that said, I've only broken mine out on a dozen or so odd jobs though so it has a comparatively easy life compared to guys that are rocking theirs from jobsite to jobsite daily.
The Cobbler
I'm odd man out here.
I don't like miter saw stands. I always use a table made with banquet table legs. I have various sizes depending on what I'm doing. I like lots of room to set stuff . ( pencils, tape measures, pcs of trim etc .
speed bump
Butte Montana
I've got my Bosch 12 inch glider on a Ridgid stand. They used to go on sale for like $100 on black Friday and it's been solid for the last 5 years. It doesnt go up and down as easily as the Bosch but I can't complain either.
rharman
SoCal
I've had the DeWalt DWX726 (I think that's what you're talking about) for close to 10 years. Works great although I only use it maybe 1-2 times a year now.
MushCreek
Upstate South Carolina
I have my 12" Ridgid slider on an older Ridgid stand that I got for $80. I can set it up or break it down in about 30 seconds. The other thing I really like is the BIG wheels. If you're going to roll across a construction site, they really make it easier. My saw is 63 lbs., so setting it up on a bench every time I want to use it is out of the question.
Dave455
Sussex, England
I’ve got my Mitre saw mounted on a (second hand) Black and Decker Workmate. Works brilliantly. Nice and rigid, adjustable height, and even collapses when not in use. Cost the equivalent of about $20.
mike93lx
Richmond, VA
Ridgid MSUV. It is very easy to manipulate, even with a heavy saw on it. I use mine with a 12" Hitachi slider and a buddy has a 12" makita slider on his. The extendable supports are good for trim, but lacking for big framing lumber , although I generally cut framing lumber with a circular saw on saw horses anyway
signcrafter
I have my bosch glider on a ridgid msuv I bought last year for 99 bucks. They go on sale different times of the year, think father's day may even be one of them. It's not a bosch gravity rise but it's a nice stand, especially for 100 bucks.
Ashgrove
Have a couple of the Toughbuilt gravity stands. Like the larger tires for moving over rough terrain.
PoorUB
Fargo, ND
I have a DeWalt DWX723. I bought it last year and love it. As far as moving it the saw just clips on with the supplied mounts so you can pop off the saw in a second, set the saw aside, move the stand and drop the saw back on in a second. The mounts hold well and the stand if sturdy. It is nice to have the saw "pop" off easily as sometimes i just grab the saw and go to do a quick job some where else and don't mess with the stand. The stand folds up to maybe a 6" square x 5 feet long.
I resided my house and replaced all the windows by myself last year. Right now the DeWalt stand in sitting in my living room all set up for cutting interior window trim. I have a window close by and roll my Horrible Freight dust collector outside and run the hose through the window.
I wanted a bit better support for the wood so I glued up some better pine 1x8 with a 1x4 back piece for a extension tables. I screwed on a hinge to the side of the saw and to the end of the board. Pop the hinge pin and it comes off. I also added a carriage bolt and wing nut to the factory supports on the stand to screw down the outer ends.
The black box has a hole in the lower side that connects to my dust collector hose.
rharman
SoCal
That plywood base is identical to what I made for my saw probably 25 years ago or more. Same radiused edges and corners and clear sealer. Only difference is I have two chest handles on mine from before I got the DeWalt rolling stand.
Toolfool
Tallahassee, FL
I built my first version (8' long) about 30 years ago. The one I posted is 10' long ( better for 16' MDF crown ) and is about 15 years old. Since that photo it was updated with beveled hardwood pieces inlaid at the edges next to the saw where the plywood started to chip. And added adjustable extruded aluminum fences to the left and right of the saw ( with flip-down stops). The holes in the sides serve two purposes .... reduce the weight ( carrying in and out of jobsites EVERY day ), places for squares, sanding blocks, pull saws, pencil sharpener, etc.. It was nice having a miter saw stand/work table all in one. I could comfortably and accurately cut, rout, and sand on that set-up. It sits in my shed now (retired ).
shoot summ
Same setup, at $100 those stands are a steal, and well worth waiting to see if they go on sale.
tarbellb
Oregon
The Ridgid is best bang for buck
there is a refurbished site that sells them cheap, $100?
mike93lx
Richmond, VA
$100 used to be the normal sale price, a few times a year. Guessing that is now near $150. Either way, we'll worth it, especially the newer one with larger wheels.
Handyandy23
Ontario, Canada
+1 for the Ridgid MSUV. I have a 12" DeWalt sliding miter saw, and started out with the DeWalt DWX723 stand for it. The stand worked fine, but it had no wheels. Which meant every time you want to use the saw you have to lug it around by hand, and it's heavy. Plus lug the stand separately. Plus find a place to store the saw flat off the stand, and then hang or store the stand.
My saw stays permanently mounted to the MSUV, it folds up and sits in a corner of my garage and takes up less room than if I had to have the saw sitting horizontally. Rolls around very easily, has nice big wheels if you're going over terrain at a job site. Loading in the truck I put the handle of the MSUV on the tailgate, then lift by the end by the wheels and slide it in. This method is pretty easy, and you're really only lifting half the weight or so, which is very manageable. For me at least I just find it way more practical.
The Bosch stand would have also been my first choice, but the MSUV does the job just as well for much less money.
kjbenner
NE Ohio
I got mine for $150 a few months ago. Just be sure to search around for the different "combo packs" or whatever they offer it in. When I ordered mine the stand alone was $200+ but the combination of the stand with a Ryobi branded sharpie was $150.
Sh40674
Iowa
Thanks everyone! Was able to find a delta locally with a 12" kobalt sliding miter saw attached for 200 bucks on facebook! Love the stand, my cousin is buying the saw. Thanks!
