Recommend me a Torque Wrench!
Jtels85
So I’m getting ready to do a tune-up and some other general 100,000 mile maintenance to my Dodge Challenger. I will need new torque wrenches as my Craftsman’s won’t cut it. I currently own the micro-clicker (or whatever the hell they’re called) round head torque wrenches and they’re complete trash. I’ve had to warranty the 1/2” three times now. I don’t like them and don’t feel safe using them.
I’ve looked at the new ICON brand at HF, Gearwrench, Husky, Kobalt... who makes a decent torque wrench that isn’t round head? I can’t afford truck brands and Carlyle is too expensive for how often I’d use them.
Thanks
seanb02
The Farm
As mentioned above, PI makes good torque wrenches for the price. I've got them in 1/2" and 3/4" versions.
skulldrinker
Bolingbrook, IL
Thanks
Here is the one i bought.
Precision Instruments PREC3FR250F Silver 1/2" Drive Split Beam Torque Wrench with Flex Head https://www.amazon.com/dp/B002XMSFIM/?tag=atomicindus08-20
Fialaja
Cripe distrbuting has some Armstrong’s at very reasonable prices
Tallpilot
Orlando
Decent torque wrench? Tekton clicker $40-60
Great torque wrench? PI split beam $100-200
Best torque wrench? CDI electronic w/ angle $300-600 (Snap-on branded has the most features)
How much do you wish to spend and what are you using it for?
jhelrey
MN
I just had a thread about this the other day.
Everyone pretty much recommends PI. I bought PI and am waiting for them to arrive.
J
Jtels85
I’m looking to spend less than $100, separately. I’m just a weekend warrior who does his own vehicle maintenance and such. The 3/8 will primarily be used to basic automotive tasks and the 1/2” for lugs.
What is the difference between a regular torque wrench and these split beams I keep seeing?
The PI torque wrenches look nice but appear a bit too pricey for me.
Briancapecoral
Southwest Florida
Check out CDI at Zoro. I just bought a couple around $100 each after you sign up for their discount. Epstein’s had a closeout CDI for $50. It’s an older model but I compared it to the new models and it was still accurate.
Tallpilot
Orlando
The click type torque wrenches use a spring in the handle to compress a ball into a detent. Complaints are that the click is less evident at low settings and it should be stored at the lowest setting to keep the spring from 'taking a set.' You can also break the cheap ones by unscrewing the handle too far because the ball is not captured and will fall out.
Opinions vary wildly on how much compression and for how long it will take to permanently warp the spring. Go to a gun forum and watch guys argue over storing magazine springs compressed or not. It is the same argument and hasn't been solved over there either.
The split beam uses two parallel beams that split during torque application then the deflected beam 'slaps' the straight one to make the click. The advantages are faster to set and don't need to be stored at a low setting. A disadvantage can be the scale increments. Every clicker I've used can be set in more or less 1 ft-lb or in-lb increments. The split beam will probably be marked in 5 ft-lb increments but the setting mechanism is inherently more accurate so it probably comes out about the same.
I would say the main advantages are for constant use. Split beams are faster to set and will maintain calibration through more cycles and tolerate more abuse (drops, etc). For DIY tasks every few weeks or longer the click types will last a long time if you don't abuse them.
I would get the 3/8" Tekton and the 1/2" PI one mentioned above from Tooldiscounter. You will have most of your needs taken care of for less than $200.
Jim c
Go to nearest northern tool store. I needed one that would go above my matco 150 ft lb limit when I was doing the front wheel bearings on my Chevy 4x4 3500 dually. I picked up one for about 80 dollars ( it may have been sale priced) last year that goes as high as 250 ft lbs. it is very high quality. Works just like the matco, just as smooth, just as accurate ( we did check it for accuracy using opposing wrenches connected together with the opposing wrench being a scale type ). Honestly, I was concerned when I bought it because of the price, but now I wonder why I ever paid so much for the matco in the first place when I could have had another from northern. It is offered in a unit that goes only to 150 also and it is less money too.
z28ke
Wake Forest, NC
I have had good luck with the 1/2 and 3/8 cobalt I got from Lowe’s. Same use as you, weekend warrior that needed a 3/8 for engine work and a 1/2 for lug nuts/suspension.
Eric29
Western NY
After reading this thread, I checked my click type torque wrench against a friend's newer and calibrated wrenches. My wrench was never abused and I always reset it to zero after using it so I always relied on it. When I set it to 80 ft. lbs., it clicked at 60 ft lbs. That's pretty far off which is why I ordered a split beam.
visionguru
Chicago
....my Craftsman’s won’t cut it. round head torque wrenches and they’re complete trash. I’ve had to warranty the 1/2” three times now. I don’t like them and don’t feel safe using them.
Complete trash? How did you break them?
Frankly, if Craftsman is trash, so are all the sub $100 torque wrenches.
