[RECOMMEND ME] Precision Electronics Repair/Disasembly Tools
jrhavener
New England
I might have better luck on an electronics forum, but I'm looking for a decent quality brand precision electronics repair tool kit. I'll mostly be working on cell phones, tablets, gaming consoles and accessories. Any thoughts?
shockwave
Marietta,ga
Most people I know use a nice set of precision screwdrivers wiha makes a good set
What will you be disassembling? It might help narrow kits cellphones,laptops
Davefr
OR
Precision screwdrivers:
Go with Wiha Std. or Wera but I'd avoid Wiha's Pico line. I'd also avoid Moody. The Wera's just fit my hand better but that's subjective. You can buy them "ala cart" at KCtools.
http://www.garagejournal.com/forum/showthread.php?t=282686
I'd also add the 65 piece Wiha bitdriver set just so you have all bases covered.
http://www.garagejournal.com/forum/showthread.php?t=317505&page=2
A crappy precision screwdriver can make a simple job miserable. Avoid the Chinese versions or the kits.
Pliers/Cutters:
I'd go with Tronex or Swanstrom. SO also makes some excellent electronic pliers. Lindstrom is OK but overpriced. Some guys recommend Schmitz but I have no idea where you'd buy them in the US.
Optivisor:
Go with the classic Donagan Optivisor with glass lens (not plastic)
Tweezers:
Dumont is the best.
Those should cover a lot of bases.
Dave455
Sussex, England
I do a bit of instrument repair, thoughts as follows:-
Screwdrivers - PB Swiss are my fav's, certainly for Metric, Pozi and Phillips, but like anything else you need drivers that are a good fit, so working on a lot of older British stuff I also have an old British made set in imperial sizes. You can never have too many drivers, so gather up old ones to grind down or consider one of the instrument sized bit drivers that take the small bits. Facom is about the nicest of these!
Pliers - I have a mix of Older British, German, Swiss and Swedish. You have to keep up to date with the quality of all these things. A lot of times you see Lindstrom being recommended, which was a good call 15 years ago, but they're nowhere the quality they used to be - box joints have given way to cheaper screwed lap joints, fit and finish are poorer, and they're not even made in Sweden any more! I'd agree with the reccomendation for Schmitz. I have a few of these and they are superb NOW, as well as being good value!
There are some patterns of regular pliers that are invaluable too. As well as Combination and Snipe Nose in small sizes I use things like Relay Pliers and Needle Nose a lot!
Other tools - I find that watchmakers tools are generally too small for instrument work, you need something a little stronger. Tweezers - I've acquired surplus medical ones over the years which work well! Add a good 1/4 drive socket set, sets of small hex and torx keys from PB, and a pick and probe set while you are shopping!
I also have an old British made gadget called a 'Multi Mini' which is basically 2 miniature vices on a versatile stand. This thing is invaluable when working in small stuff but I havn't seen one for sale in ages!
