A&P mechanic
Hi GarageJournal,
I have a Veepeak Bluetooth adapter that connects to the OBD Fusion app on my iPad and it says there are no diagnostic trouble codes pending or saved.
An internet search shows the below code is Toyota specific, so an OBD scan tool is not good enough to read the code.
This scan tool will only be used periodically at home.
It would be great if I could connect to my Ipad, have no subscription or use a scan tool that uses normal batteries like AA etc, so the tool does not go bad in several years.
I have an iphone and an ipad. (I do not have an android phone)
What do you all recommend for home use?
Thank you in advance!
- What do you recommend to read the check engine light code on a 2024 Rav4 hybrid with 40,000 miles?
- “Maintenance Required - A malfunction in the electronic control of the engine throttle or automatic transmission has been detected. Contact your Toyota dealer to have your vehicle inspected.”
- I do not see any lights on the dashboard and only see the message on the big screen.
