Recommendation for a bolt extractor socket set
T
Tbird22
I work abroad and the set they have is for sure rebranded and tools are more expensive here than in the states. Figured I can get a better set for cheaper
Professional Tool User
BC
I actually have that Maximum brand Canadian tire set in the image. Those are dirt cheap when on sale and work fairly well.
englishsam
UK
Irwin bolt grips...
They are cheap enough that you don't need to get some knock off inferior version. You won't be using them all the time.
setfocus
rust belt
Irwin bolt grips...
they work great for removing wheel locks and do wear out once the spirals get mushed down
I believe the devil invented wheel locks :evil: ... You leave the key in the car, thief breaks into car to retrieve it, extra damage. Leave it at home, can't put the spare tire on when you get a flat... Wheels are over torqued or never taken off? key breaks... or if it gets lost, I have to spend a bunch of time breaking the them off (unpaid work for me), possibly causing cosmetic damage to the wheel.
Farmall450
Marengo, Illinois
https://www.hudsonbearings.com/products/turbosocket/
These guys are the maker that are rebranded by everybody else. For years, Craftsman has been the most economical place to buy them. With their supply drying up, not sure where is best now.
Snap-on/blue point sells them, Irwin has a 5 piece set, Cornwell sells them, others do to. I'd search for damaged bolt/nut remover and see what comes up.
Luckily I was around for the Craftsman train. I'll miss all the good, US, Cman rebrands for less $$$ (hose pinch pliers come to mind)
bonneyman
Desert SW
I keep finding individual ones at pawn shops in their bin tools. No big sizes, but I've got 4 of them for about 50 cents a piece over the past couple of months.
