Recommendation for brad nailer needed
ImportTuner
I'm looking at getting a brad nailer to replace some baseboards and was wondering if anybody had any recommendations. There are so many brands out there .. Thanks
archirelic
texas
I've got a Porter Cable brad nailer that I've been using for the past 7 years or so...in a finish carpentry/construction environment and it's held up exceedingly well.
rlitman
Long Island
I've got just about every size in the PC line of nailers.
I use the brad nailer on shoe and cap molding, but prefer the pin nailer when I want to fasten a miter.
The HF nailer/stapler combo is pretty darned good too (I love it for stapling), BUT the wider hammer leaves a larger impression in the wood that needs to be puttied before painting.
If I'm worried about the surface finish, then I reach for the PC.
BQuicksilver
Do you have Dewalt 18v tools? Their new 18ga brad nailer is great if you're willing to trade some weight for not lugging a hose.
I
ImportTuner
I'm looking for a pneumatic model .. the PC sounds pretty good so far; does it come with a case for storage since I won't be using it that much?
Toolfool
Columbus, Ohio
For occasional use, you're OK with the Porter Cable, or Senco. Using it professionally, I've worn out two of them in two years, so they're **** to me. Switched to Fasco. Three years of heavy use and still going strong.
back2class
I've owned two brad nailers. The Campell Husfield was a jamomatic and my stanley/bostcih has never jammed once.
djjsr
In the cornfields
I currently have 6 of them of various brands but always end up using either the Bostich or Paslode. They have never jammed or misfired. The cheap oddball brands are a crapshoot. Sometimes they work, usually they don't.
btw, that one that toolfool posted is a really good deal.
KenC
oklahoma
Brad nailer, or finish nailer?? Base is normally done with a 15ga finish nailer. Brads are too short ( 1 1/2" max) to reach through the bottom of the base (usually 5/8-3/4"), drywall (1/2) and still provide enough framing engagement to hold well. The length + being really skinny doesn't equate to a good solid attachment. 2 - 2 1/2" finish nails are my preferred method. Senco is my choice. Have a full head framer, clipped head framer, shingle nailer, shingle stapler and sheathing stapler. All have been very good.
I also have a few lighter brad nailers and staplers, all Porter Cable. The seem significantly more homeowner rather than pro tools. I'm not a pro, just like good heavy duty tools.
DHCrocks
Hawaii
I've got a Senco, it's rarely seen use but when I do use it, it hasn't given me any problems. I think brads are all the same but just check to be sure that whatever model you choose that the brad nails are easily available in your area. I know some of the larger guns use specific nails so you might have difficulties in restocking.
Toolfool
Columbus, Ohio
The Bostich I linked shoots up to a 2-1/8" 18 gauge brad. One in the plate and one in a stud every 16" or 24" is enough for base trim. Easier on the painter too.
mossyboy6
St. Pete, FL
I have this gun, works great.
I shoot once about every 12" at an angle for base.
