Recommendation for Swing Set Frame
Clutch71
Mid-Missouri
Hey, everyone, I just finished building a swing and have been over analyzing what type of frame to build for it. This swing will be for adults and will be on the outskirts of a fire pit I finished earlier this summer. Just an FYI: typing in "adult swing" into google may or may not give you the results you are looking for. Anyhow, some background:
The swing itself is 6 feet wide with 2x4 frame construction and is pretty heavy. I am also pretty heavy at around 280 pounds, and the swing should hold 1.5 more people. The soil here is pretty much all clay. My yard slopes with the high side toward the north. Plan is to have the swing facing south. I tend to overbuild everything and here are my 2 options thus far:
OPTION 1: Two post swing with overhangs to match my pergola. Plan is to use two 12 foot tall 6x6 posts (cedar or PT, cedar would match the pergola better). Sink 3 to 4 feet in the ground and use 2 or 3 bags of Qwikcrete. Use a 4x6 connecting beam sandwiched between two 2x8 boards. Still playing with design, but am looking at notching the beam and have the outer 2x8's to sandwich it to the 6x6 and also act as an I beam. I may be over-engineering.
OPTION 2: A simple A-frame using four 4x4 legs with a 4x6 beam. Plenty of cross bracing (double 2 by boards at the top of the joint, somewhere around the midpoint and maybe even at the bottom. Due to the slope, I could bury part of the bottom connector). I've seen the metal brackets, but it seems like you could get the same sturdiness from a well designed joint where the legs pinch the beam and use galvanized hardware to tie it together.
The two post will probably look better. The A frame could be moved around.
Anyhow, thanks in advance for any suggestions. Will post up pics later.
A billion years ago, my Dad and Uncle built one for us kids out of 2" Schedule 40 galvanized water pipe. No rust and I think it would hold an elephant. Set about 1' deep in concrete.
In The Doghouse
South of Due West, West of NinetySix in SC
This is a simple one I built a few years ago. 6 x 6 vertical posts set 18" in the ground and 4 x 6 cross post. It is simple and very solid.
Falcon67
Merkel, TX
Glad you clarified it was an "outdoor/public" type of adult swing. :lol: Around here I've seen them build from oil field pipe. And baseball back stops, goal posts, fences, you name it. They nearly hand you a joint of pipe when you move in.
jp_over
East TX
Any update on what you ended up with? Thanks!
LifeLongWNYer
South of Rochester, NY
I like Falcon67's comment about being handed a joint of pipe in Texas. I worked in the oil patch for a few years and always marveled at the neat things made from welded up pipe and casings. Everything from gates, to swing sets, from wagons and trailers to mail box supports, I saw lots of interesting projects. The "bump gates" out on the range land were really cool.
I envy you, in the land of "free pipe." Up here, in Western NY, new pipe is expensive and used pipe is either very hard to find or it is in 6" lengths.
theundermount
ON
I think option 1 would look great, notching the posts at the top like this
jp_over
East TX
Lots of good suggestions - thanks! I guess the OP hasn't been active here in a while.
Milton Shaw
I have one made with 3 1/2" rigid conduit with a couple of long sweeps and a 5 foot section of conduit between the uprights. I have moved it once and its still quite rigid. This was some used conduit where some remodeling had been done on a commercial building.
