I have 2x4 rafters which are 2' on center.
What is best way to insulate..not looking to blow insulation, would prefer a combination of batts or roll type insulation.
1) Put standard fiberglass insulation that's appropriate for the climate (probably R-38) between the joists. Since this insulation will be 12 inches thick, the top will sit above the joists, but will not cover them. Some amount of thermal transfer will still occur through the joists themselves.
2) Put insulation meant for 2x4 R13 framed walls between the joists (which will be the same height as the joists), then lay a perpendicular layer of attic insulation (maybe R-30) on top of them.
