Recommendations for ignition scope?
2ndGearRubber
Pittsburgh
Its USB-C powered. They include a wall wart to covert 120v ac but I showed several solutions above utilizing a battery pack and 3d printed piece to hold it in place which is very slick, or a milwaukee/dewalt battery and usb-c charger.
Thats my point, your trying to make it seem like a ball in chain,but its form factor isn't all that different when you look at both as systems as a whole, maybe smaller is you put the mounted battery pack on.
This is only a feature on that is directly on 4444 scope that I see, not on the other automotive picoscope such as the 4225, 4425a and 4823. The 4444 doesn't even appear on their automotive page and is 1525dollars(vs 400) for the unit alone. The scopes can use differential probes however, as can the rigol. Or am I not following what your saying?
Yes
Again you can output to a screen as large as you want or a computer. HDMI, LAN, USB
For automotive use I don't disagree. I understand that the software for the auto use is superior as I have stated before in this thread? But on the flip side its more of a one trick pony mainly for auto use. The wizard wasn't wrong when he stated that the hardware was outdated on the pico. Remember, the rigol that we are talking about is a sub 400 dollars scope, they make much more capable ones as well. The rigol isn't an answer for a pro doing it day in and day out. But for a hobbiest that also does electronics it might be a good solution.
My past experience with laptop based interfaces is actually why I think it a bad idea.. I have had engine tuning hardware for cars and motorcyles since the early 2000's that I used with some frequency in the past, and its all trash now. Your dongle in your old systems was connected via DB9, its damn hard to find a laptop that has DB9 now and the usb to db9 adapters and trying to get them to work is a joke. My current laptop only has 1 USB anymore, the rest are USB C Trying to run windows 98 programs on window 11 and talk correctly on all the porting is a nightmare. None of my old laptops will boot anymore except for one ancient 486 for some reason.
IF you can chuck a 1000 dollar laptop, what is a 400 dollar oscilloscope?
I stated differential, the 4425 is actually listed as "floating" input, which still lets you voltage drop and accomplish the same thing with 1 channel rather than 2. I will admit it can be annoying to deal with 4 channels worth of grounds sometimes when not using that feature. The probes I've seen listed as "differential" for the stuff like that Rigol are probably fine for board level work but the little hooks and 3" space between each lead sections doesn't work on a car. Of course that's solved with lead replacement, and many other scopes don't even come with leads so it's no big deal to just pitch them in the garbage. 1/2 to 2/3 is the scope, the leads and extras are the rest. Not including an interface of course.
If you'll deal with a choppy live trace, but good captured data, a sub 500 laptop can do pico4425 stuff. AFAIK it's still windows only software, it just needs to be able to run windows 10. Good performance which doesn't frustrate in a stressful environment means ~750, less if you deal hunt. But you also get a computer, or just use the computer you already have. The picoscopes, not just the automotive type, which I have seen all do need a normal USB 3.0 not a C. Maybe that will change. My only complaint with that Rigol you posted as far as form factor is it's basically a portable design, which isn't inherently portable. Weird choice but whatever. That's why I added the need for an interface for pico/snap-on. Both types aren't usable on their own.
The only reason I bring up pico, which is an automotive specialty as you said, is it's a thread about automotive specialty use. There's lots of statements which float around about pico being outdated, but in the real world of automotive repair it's king. The hardware isn't all that relevant to the discussion as the hardware is beyond what's required to acquire an automotive signal. Now if you're going for non-automotive use I'd bow right out of that debate because all I know is automotive use. But a 4425 is the standard for automotive diagnostic work. I think it's flawed to criticize a Picoscope 4425 on specs, when the specs have earned it a crown among automotive specialty scopes. So the specs, while "low" in the grand scheme of things, are perfectly fine as a frame of reference for tool used in automotive specifically.
Whatever someone is shopping for, if it's automotive in purpose, those specs will give you more information than is typically relevant. You can go up from there, but the signals won't get any better. Even with those specs it's pretty hard to set the scope up so badly you distort the signal. Eventually you can be stupid zoomed out and not have the resolution to zoom back in, but at least with the 4425 you need to be doing pretty awful setups.
If one could be careful with that Rigol, I'm sure it could do the job. But for basic stuff a $250 pico and the laptop you own can too. You could probably slum it with a $130 2204A if you set the thing up with any sense. All of that said, for basic hobby use an Amazon alphabet soup brand tablet scope would suffice. 2 channels, trigger and parade, you'd need to source probes but they're ready to go. Some have better specs than a 4425. Gamble with a Hantek for ~200, comes with the secondary leads ready to go.
Will only take 40v max input. No idea if it's junk, but on specs alone it should work. If compared to the resources available 50 years ago, I don't think tracking an ignition signal would be that hard. That's I suppose the root of my question - why the Rigol? Sure it's got better specs. If you want the best, 4425/ATS are in charge of automotive specialty tools. If you don't, and most people don't, you're limited by the required specs for the signal, which ain't much. So why spend more for a Rigol?
That weak *** scope intergrated into snap-on tools can do most automotive signals. 6 mega samples per second, 3 mhz band width. Communication signals will always look a little messed up, and you need to set it up right as the zoom function works backwards. But it's got a built in ignition scope on the 4 channel models.
EDIT: 6 mega samples with all 4 channels going, 1.5 as a single channel. LOL A single channel on the 4425 is 400, despite being old tech.
Schurkey
I'm interested in acquiring an oscilloscope for test/diagnosis of automotive ignition systems. Various old-school, CRT models pop up on Ebay, and they're under consideration, however I'd be keen to hear of any modern units that are out there, and the pros/cons of what might be available. Ability to view a secondary pattern parade is an absolute requirement.
I've worked with ancient Sun, ancient Allen, and ancient Snap-On Counselor/Counselor II automotive oscilloscopes. I have a Matco-branded, made-by-OTC hand-held scope/graphing multimeter that I'm still getting used to.
When it was my money, I bought a Snap-On Counselor II MT3000. The MT3000A is slightly preferable, having some additional protection circuitry and the ability to display Lambda when connected to the optional exhaust-gas analyzer.
An automotive ignition 'scope is one thing. The Snappy has the ability to display (and digitally freeze) all the useful waveforms, and in addition can be used with distributorless ignitions, can perform cylinder shorting including an automated shorting program that also has even/odd cylinders, has optional accessories for low-ampere and high-ampere loads, cranking variation (dynamic "compression testing") vacuum waveform, and the ability to synch those patterns to #1 cylinder. It'll also interface with the old Snap-On MT2500/MTG2500 scan tools, showing more lines of data on the 'scope screen.
Parade waveform available, multiple Raster, where all the cylinders are stacked from top to bottom of the screen, is not. But all the things that the multiple Raster pattern is good for, is accomplished with different facilities on the 'scope menu--Dwell amount, dwell variation, etc.
allen-syncrograph-1-jpg.2210566
That's exactly my first distributor machine. I connected an HEI module and some wires so it would work with HEIs and other mag-pickup distributors. Had the most wonderful, bright strobe light. Went underwater in a flood, and that ended it.
john.k
Brisbane Qld Australia
I have a Ford truck with the helmet distributor ......was running OK on my near nuff setting.............anyhoo ,everyones saying take it to this guy ,he s got all the Ford ignition setups ,Allen scopes ,you name it..............so I took it to him ............six months later ,he still got it ....fortunately I also got a crab dizzy off a 1945 motor.,which is on the truck now..............i told the guy I want my helmet back ,no BS ,no cost.
richfinn
Leeds, Yorkshire, England
There are three major selling points for Automotive Pico scopes IMHO
1. "The Software", it's easy to use, mobile in nature and will help a novice operator navigate their way through to a respectable level of performance
2. "The community" of Pico users, if you need help, it's always there, 24/7
3. If your laptop or tablet goes "**** Up" download the software again onto a replacement unit "Free of Charge" and carry on working.
We know that the electronics industry can make far more powerful/faster hardware, but its overkill for automotive diagnostics.
I have used other scopes over the years going back to the days of "Crypton Tuners" and early DSOs from Tektronix and Fluke, they are all great and way better than not having anything at all, I suppose Pico just became the default "pro choice" because they invested in getting Automotive engineers involved to work on development of the software and create the community for the users (it's like they actually want to keep you involved in the loop and not just take your money).
I still maintain if you are looking for more of a traditional "live scope" look at the GTC 505 (it's digital but simulates a live ignition scope very well)
All EXCELLENT points !
My point is, the PRICE of the Pico is keeping many people from buying one ! Someday, likely soon, a key component inside that 'scope will go out of production !
richfinn
My point is, the PRICE of the Pico is keeping many people from buying one ! Someday, likely soon, a key component inside that 'scooe will go out of production !
I don't know too much about the technical side of equipment internally it's kinda outside my "scope of knowledge" 😂, I'm just a satisfied customer I guess, if it helps me fix cars and they send me stuff in a reasonable timeframe, I can't really ask for more.
Pico are a decent British company to do business with in my limited experience 👍
VolvoRyan
Kentuckiana, USA
Hantek pickups are pretty cheap and work fine. Rotkee stuff is nice as well. Hope they survive. Literally.
I've an Autel MP408. I don't think they make them anymore. Labscopes and a copy of Paul Danner's book are endlessly useful.
-Ryan
dnschmidt
Phoenix, AZ
Look up the latest video from Royalty Auto Service on YouTube. OTC just introduced a $250 tool that does exactly what is being asked for above. Case closed.
VolvoRyan
Kentuckiana, USA
That tool looks not worth the nearly $300 that Amazon wants..
Rotkee has scope adapters that'll let to look at multiple COP's simultaneously for $30-$50 last I checked. Pico has to have something similar. A key to waveforms is comparisons. I wanna see known goods next to the dud. That's how you find systemic problems.
You can get into Pico's non-automotive stuff for pretty cheap. The sampling isn't bonkers good, but it's a scope. There has to be other scopes at reasonable prices.
-Ryan
richfinn
-Ryan
It's worth every penny of $250 in my opinion (watch the other videos I posted), it's actually a very well made little device (Made in Canada) with micro USB charge port being my one criticism.
I've actually got both the Pico COP paddle (expensive) and the ROTKEE secondary pick up (so cheap you will laugh), they are all great tools in different scenarios.
The GTC has some more cool tricks that Sherwood didn't show in that video BTW
You can plot and compare RPM using chart mode and current ramp ignition coils without an amp clamp for example.
joecon
Can you tell what cylinder is missing? I don't want to sound stupid, but I been in this industry for 50 years or so and can you tell me what a helmet dizzy is? The helmets I have are supposed to keep you from being dizzy.
dscheidt
One of the styles of distributor fitted to ford flathead v8s.
2ndGearRubber
Pittsburgh
I can detect misfires by putting my hand over the pipe ........can any of these reset the vacuum brake on a helmet dizzy.
Ah, but you can't tell which cylinder, and why specifically the cylinder is misfiring. I can take the tailpipe pulse, sync it to a cylinder, and then use that to scroll through the buffer worth of waveforms to see the exact ignition event which caused the misfire. Yes, a single misfire which occurs one single fire cycle over several minutes.
I can sit in most misfiring cars and detect misfires, to the point of "yes Lucy, it has a misfire", it's easy.
Car parts which haven't been used for 70 years. LOL
2ndGearRubber
Pittsburgh
Only 50 years .....you got a lot to learn,
Build through 53 by Ford for US automotive market use per wikipedia. Although I believe they were still used as stationary power past that point for some machines much like the model T engine.
I'm not sure correcting me to "only" 50 years make them any more relevant.
But on topic, yes, these modern scopes could give you an ignition pattern on that engine built during the depression. You could use it on a Model T engine with a trembler coil, although I'm not exactly sure how the primary area of the coil pattern would look. Would be interesting to see. Age doesn't matter, it's a secondary pattern. It's not a distributor rebuilding robot, so it's not going to fix your distributor.
joecon
This why they started using scopes to diagnosis ignition systems in the 1950's. It is easy to tell you have a miss but, what is causing the miss can be harder. Most times it is easy to find the cause, and you can do it by pulling off plug wires or replacing inexpensive parts. A scope can tell you what is wrong and not only with the ignition but also in the engine. My 1960's Allen scope has a tachometer, dwell meter, voltmeter and we would use a vacuum gauge and compression gauge to diagnosis engines. A modern scope can do everything these do in much less time, with more accuracy, plus a whole lot more. Easer and better.
