recommendations for scissors for blister packs
BTL-A4
Santa Clarita
I'd like to get some scissors to open plastic packaging. Tin snips are not working for me. I've seen offset scissors that seem like they would work, but I thought I'd ask and see if anyone uses them and find out how well they work. Here are my choices:
Wiss, $10. 5-star reviews
Milwaukee, $16, 5-star reviews
Fiskars, $16 at my local hardware store, 4.5-star review
Thoughts and comments from anyone who's used these? I'll consider other brands and designs.
Thanks!
BroncoAZ
My buddy in PA sent me a set of the Wiss, I really like them for everything I’ve tried including blister packaging.
tincanoe
home
Engineer PH-56 $14.87 on Amazon, or about half that if your putting together a Amazon Japan order where shipping would make sense.
whateg01
doo dah, kansas, usa
.., but it doesn't work great for cutting along the edge where the heat melted the plastic together.
Then don't cut there! Cut in the big flat areas. Cut along the corner where the plastic rises up to go over the item contained within. Cut somewhere else. If the carpet knife doesn't have a pointy enough point, use another knife to pierce the plastic, then finish the job with the carpet knife. Biggest word of caution with a knife of any kind is make sure when it breaks through the last bit of plastic, make sure it's pointed somewhere safe. Otherwise, I've used trauma shears before and they do keep your hand away from the sharp plastic edges. If I'm in the house I just use a sharp utility knife, but in the shop, I still use the bandsaw.
bluedog225
Texas
I have one of those. If I can get it into the plastic it works, but it doesn't work great for cutting along the edge where the heat melted the plastic together.
I usually start in the middle and cut out. Seems easier and safer.
Ohio Andy
Columbus, Ohio
Yes, the wiss work well
Wiss - Pro Shear, Heavy Duty, Tradesman, Titanium (CW10TM), multi, one size
I have subs from Wolf made in USA that work better but more expensive. Let me know if you want links to those... I can't grab that now.
Junkdrawer Dog
LV NV
I use a pair of Fiskars Amplify mixed media shears in the 10 inch size. They'll cut nearly anything that isn't sheet metal.
These work well also, but not as unstoppable as the Wiss, but easier to find. These reside in the kitchen
Klein, which purchased Heritage Cutlery a few years back and renamed it Klein Culery. Lots of made in USA options: https://www.kleincutlery.com/. Personal favorite is Klein G210LRK (10 = 10", LR= Large Ring, K = Knife Edge): $35 on Amazon. It makes those packages tremble in fear
Those look pretty good also, for ease of purchase
mike93lx
Richmond, VA
Ohio Andy
Columbus, Ohio
I find these wolf utility shears to be very nice, especially when I want to cut reasonably small things that are heavy. I think these other ones I have for a little over $30
Also have one of their larger ones. I think it's 11 in and those things are really heavy duty but harder to make these sharp turns when I'm cutting the smaller heavy plastic stuff, but it'll go through almost anyway and those are about 75
I have a vintage Wiss utility shear like that, and don't like it for blister packs that much. My Wolff's get more use there, tho both are in easy range in the kitchen
GeoBruin
I bought some scissors for exactly this purpose. I still haven't been able to use them however, because I can't get them out of the package.
Seriously though, Harbor Freight has these Pittsburg scissors for $10 ($7 with the current coupon!). They work great for this application. They have a slight serration, and one blade has a little belly on it.
Edit: I forgot to mention, I also really like that these will fit in my pliers rack. Scissors with a loop handle are too tall.
mgeoffriau
Olfa scissors, specifically these: https://www.amazon.com/gp/product/B001D3G51G/?tag=atomicindus08-20
Heavy duty without being heavy or clunky like snips. Short blades so you can make sharp curved cuts with plenty of leverage. Micro-serrations so it cuts through thick plastic rather than sliding off backward. Great quality and only $12.
Fedwrench
Valley of the sun
SK 7 Inch heavy duty scissors. Drop forged blades. Although they've doubled from the $7.99 I paid, I think they're great for cutting plastic blister packs. If you don't like green grips, you can get the Duratec version with light blue grips. I think Last Best Tool did a You Tube video on them.
BTL-A4
Santa Clarita
Hahaha $12, $15, $19 scissors are a joke.
Get real scissors as have been mentioned already, or my Favorite CUTCO. As always with Amazon they will show you cheaper ones but this what real scissors cost.
https://www.amazon.ca/s?k=cutco+sci...x_e&tag=atomicindus04-20&tag=atomicindus04-20
Over $200 for scissors. Thanks, but that's a bit much for me. My SIL sold Cutco for awhile. We bought some $50 frosting spreader from her. We still have it. Everytime we use it we mention how much it costs. I appreciate well-made items, but it seems like too much. What are these made of and what makes them so special, anyway? Not trying to be a jerk, I really want to know.
Here's some that were even more ($434!):
BTL-A4
Santa Clarita
The Wolffs look like a solid choice. Made in the US, too. Thanks!
  • Like
Reactions: RTM
BTL-A4
Santa Clarita
I found these also:
Zibra Open-it, $17, 4.37 stars on Amazon:
Anyone ever try these? They look gimmicky, and don't seem like they could have any other purpose besides opening blister packs.
