recommendations to on finishing floor
Stevenanto
Montreal Canada
I know I am posting a lot these days but I want to do it right the first time.
So the foundation slab was just poured yesterday and it is was polished by helicopter too. How should I plan on finishing my floors? should I just seal it? epoxy? or leave it?
the contractor polished it because I told him I didnt like dirt and dust accumulating like another foundation I have for a mini house that we built. So he said polishing would help that. He is telling me to seal it a year after. I was thinking of sealing it after the rough goes up. What do you guys think?
PNWguy
Near Grants Pass, OR
I've been putting much thought into the same question. I think I'm going to end up with a densifier and possibly wax. But I just learned that the floor would be slippery, so I may skip the wax.
I'm actually pretty frustrated with the process of choosing a floor treatment.
Armorpoxy
If the floor is burnished now by a burnisher, you most likely will need to grind to use an epoxy since it's so smooth. Consider the penetrating Ghostshield System. Almost no prep, and inexpensive relative to a high solids epoxy coating system.
Stevenanto
Montreal Canada
Well its not smooth like a real polish. All that was done was the helicopter so the concrete is still rough, but smoother than what it would have been without the helicopter.
RPH
Michigan Thumb
It depends on the purpose of the building. If you’re going to be doing hard fabrication in the building then I would do the floor different from one used as a display for my cars and motorcycles. Tell us what your uses and plans are and we can help guide you to the appropriate materials.
Stevenanto
Montreal Canada
Hi,
it is almost 600sqf, with cathedral ceilings.
It will be used for mainly storing one car in the winter and sometimes two. Might wash them once in a while in garage. I will have some tools where I might do some minor work (wood). There will also be a lot of storage and cabinets, lawn mower, snowblower.
RPH
Michigan Thumb
So stains are a possibility. Look into the Ghostshield products. Vendors here carry it. If you do use Ghostshield it will preclude you from using other coatings. Nothing will stick to it. It won’t change the color of the concrete or the feel of it and it won’t be slippery. Easy to apply too.
Stevenanto
Montreal Canada
that stuff looks great, but I dont think they sell that in canada. amazon.ca has it for 271.00$ lol
RPH
Michigan Thumb
Check with vendors here, some carry it. All the vendors here are great to work with and have helped many out.
