Recommendations to protect tools from rust
Helipilot
My Mother gave me the steel square my Dad used on the war emergency pipeline that he worked on during WW2. He bought it in 1942 and I used it while I was his welder helper and working my way through school. He was an excellent pipeline welder and I learned a lot. The square accumulated a fine layer of rust over the years which I just finished cleaning off in my glass bead cabinet.
I usually use a Carnuba type wax on the machine tables ( Table Saw, Drill Press, Shear, Box Brake, etc.) to keep rust from forming but not sure about the square. It has a lot of sentimental value as you can guess.
TheClaw
Chicagoland
I regularly wipe things down with WD40 but wax is good idea. Not sure what the best preservative is. I have a number of tools from my grandfather and great grandfather.
LG63
Now that it's been bead blasted I think a light film of mineral oil would be better than wax.
nicksnothereman
In the Mojave
For utility stuff I use either marine oil or marvel mystery lubricating oil. Has worked well. For other stuff (that I won't touch all the time) I just use mystik (or tubed grease...prefer citgo but haven't seen that it a while).
I would use marine oil if you're not going to use it a whole lot. Pretty cheap too. It's a gear oil so heavyweight. Overkill? Yes. But works well and is thin enough to massage in (vs. worm gear oil). Use it on working knives all the time.
Shadowdog500
Down the shore
I use Johnson's paste wax on all of my metal tables every 6 months or so. Never though about using it on a square but I guess it wouldn't hurt.
Do you have a pic of the square? I'm curious what it looks like.
Chris
LS6 Tommy
Northern NJ
Wurth Rost Off works great. Spray, let it sit, wipe of the excess. Done. I've used it on raw steel & iron car parts & they stay rust free for years in unconditioned garage storage. Once a year on driven cars.
Tommy
