Recommended tools for a truck mechanic apprentice?
AdamD87
Hey guys,
Quick question I got a position at my current employer as a diesel mechanic apprentice. Ill be maintaining a fleet of Kenworth and Peterbuilt Trucks and trailers. I have experience in a auto shop doing oil changes, brakes and suspension and steering work. So I have some tools required for that but I have no experience with big trucks (other than holding the steering wheel). Any advice as to what I will need for them?
Ill be taking an aptitude test tomorrow and ill be getting a tool list at some point I am sure but I figured it would be nice to get some more opinions. I did pick up a set of large metric SK wrenches today off craigslist just cause the price was right.
Sent from my SM-N900P using Tapatalk
Rlfd213
Buy the biggest tool box you can't afford. That's all you need.
RedneckWelder
The Ghetto Kingdom of Methlandia
Find out the tool list and build from there. Your shop may provide larger tools in the tool crib so you might be able to hold off on those for a while- being an apprentice they won't expect you to have everything at first but just having some basic tools is a good start.
Big channellocks and big oil filter pliers and a big strap wrench- all these are cheap (channelock for the pliers, you can get the strap wrench for $20-30 either on the truck or at NAPA)
RedneckWelder
don't buy any 3/4" drive stuff made in China.
shop Ebay for used stuff. every now and then a good, used, US-made 3/4" drive set will get listed. I've posted several of them in the 'Ebay hot deal' thread here.
couple of them were listed in the last 24 hours for HALF of that Wright set on Amazon.
Ebay - 'advanced search' - enter '3/4 socket set' - words to exclude: snap snapon snap-on cornwell Pittsburgh gearwrench - check "used" - check "US only" - select "newly listed".
there were at least a dozen listed since the first of the month: S-K, Proto, Wright, Armstrong, etc. - for $200-$300 you should be able to score a nice set with all the accoutrements and box.
Empty Pockets
Rural New York
The SK wrenches are likely a good start. 3/4 drive is a must.
The several shops that my carrier operates supply the larger tools, but that varies by company.
CL and eBay are good places to look for good used tools. If you don't get the tool list in short order, you might want to talk to the truck mechanics and get suggestions from them. Buying tools off of the truck are expensive, you can save money buying from SK or Wright.
Good Luck with the new job
AJO
1/ big hammer 2/ bigger hammer 3/ sledge hammer 4/ 5 foot pry bar 5/ 11/2 inch pipe 5 foot long 6/ 2 foot pipe wrench 7/ 2 foot adjustable wrench and just for a back up a 4 foot pipe wrench. This will help you get started.:thumbup:
A
AdamD87
kctyphoon
Jersey/Staten Island
The fleet mechaincs that work at my garage work on everything from Honda civics to diesel f750's, gmc 7500's bucket trucks and freightliner/ international digger derricks.. The tools are supplied to them by my compay. Power tools are Milwaukee, pliers are channellocks and most of the tools are gearwrench w/extreme tool boxes.. The mechaincs say they work fine. I would have guess proto - but they said the company has a deal with a vendor and most of what they provide them with is all gearwrench.
A
AdamD87
I had nice set of matco pry bars that got ripped off! My *** is still chapped about that happening 6 years ago. I'll be on ebay getting another set I guess. I have already broke my share of HF pry bars. But where do I get a 5 ft pry bar?
RedneckWelder
You can get a ******* huge Mayhew 54" for about eighty bucks on Amazon.
My snap on driver has the four piece set of prybars with the nice oversize striking handles for $130 this month- I brought a set today. This style, I really like the handles on them. Doesn't look like the set is on their website yet though.
Or you can always buy the Mayhew set too that is also great.
DoctorDiesel
Cornfield, Nebraska/Iowa
Ah, I almost forgot about the cheater bar pipe! Make sure its long enough so at least 3 people can stand on it or hang on it.
DoctorDiesel
The one I use is a Crapsman and its actually held up pretty well. And it gets BEAT.
RedneckWelder
Farmall 1066
Suburban Rockford, NE
While big tools are a necessity (insert **** joke here), a lot of what you'll be doing is small under dash, in door panel type stuff too, so don't overlook small tools too.
Good Fluke meter, lead set, quality back probe pins, butane soldering iron. Maybe a power probe, if you know how to use it safely. I'm sure you'll be chasing your share of electrical demons.
abvw
Toronto, Canada
Everything gets pulled off by power tools. Hand tools are for small delicate repairs. Take a mental note of what common tools/sizes your coworkers/mentors are using on the job.
3/4" drive tools and wrenches over 1 1/2" are usually shop supplied.
toolaholic
PA
Is that Williams set USA?
That's a pretty good price
Tawain. I have a Williams 33mm wrench to turn bushing on kd crankshaft pulley( harmonic balancer) installer kit that's made in tawain and is a very very nice wrench.
A
AdamD87
I know some 3/4 power tools are supplied. Not sure what all that entails. Like if I still need the 3/4 socket set or if that is only impact stuff.
powerstroker
Ontario
My battery powered tools are my best friend. Electric ratchet and impact get used every single day. A lot of people seem to get hung up on the big tools when talking about working on big trucks. In my experience I haven't needed big stuff all that often. All of our 3/4 and larger stuff is shop supplied and I don't need it very often. Now it could be different where you will be but I wouldn't jump right out of the gate and buy big stuff. You will for sure need good basic hand tools which it sounds like you have. Hammers and pry bars are a must. A nice long pointed punch is nice for draining oil filters before pulling them off. I also recommend some sort of hose pick. I love mine for rad hoses and charge air pipe boots. Another thing to check out would be some type of heel bar for popping out wheel seals. It all depends on what you're doing. Let us know what kind of work goes on in the shop and what your tool list says. I always like talking about tools and fixing trucks. Good luck :beer:
A
AdamD87
Anybody have an opinion on aircat? I would like to get a new 1/2 impact and possibly 3/8 before starting. Aircat has been calling my name since my old IR is... well... old
A
AdamD87
My battery powered tools are my best friend. Electric ratchet and impact get used every single day. A lot of people seem to get hung up on the big tools when talking about working on big trucks. In my experience I haven't needed big stuff all that often. All of our 3/4 and larger stuff is shop supplied and I don't need it very often. Now it could be different where you will be but I wouldn't jump right out of the gate and buy big stuff. You will for sure need good basic hand tools which it sounds like you have. Hammers and pry bars are a must. A nice long pointed punch is nice for draining oil filters before pulling them off. I also recommend some sort of hose pick. I love mine for rad hoses and charge air pipe boots. Another thing to check out would be some type of heel bar for popping out wheel seals. It all depends on what you're doing. Let us know what kind of work goes on in the shop and what your tool list says. I always like talking about tools and fixing trucks. Good luck [emoji481]
Do you use a 1/2 electric impact? Is it really taking place of the air stuff?
RedneckWelder
I have an Aircat Nitrocat 1200K. So far it has survived a year and a half in our heavy equipment shop. Many of my coworkers have the same impact and have similar good luck.
I think it is well priced for an apprentice, and I like that they are quiet and powerful.
For 3/8 I use the blue Cornwell one but I got it at a fairly good deal. I'd get the 3/8 version of the Nitrocat in a heartbeat if I had not brought the Cornwell.
powerstroker
Ontario
I still use air for my 1/2" gun. My IR 2150 has been amazing and I haven't bought a 1/2" electric impact. I use air for my 1/2" gun, die grinder and occasionally my air hammer. My 3/8" air impact hasn't moved in a long time.
DoctorDiesel
I dont always have access to air, so I almost always use electric. Have to bust them loose by hand most of the time (we have ****** Dewalt 18v stuff at work) but they are still great.
I just bought a Nitrocat 1200k last night actually. Used in good shape for 50 bucks, couldnt pass that up. Got it to use in my shop at home though.
A
AdamD87
Excellent point. That is some stuff I am guilty of overlooking and have needed many times for home use. My electrical diagnosis anility and tools are a bit lacking. Never had a problem I could not figure out but it usually involves a lot of googling. But I guess without diagrams what else ya gonna do. My question though when using a power probe or load pro or what have you. How do you avoid frying a module?
powerstroker
Ontario
You have to understand how the circuit works and where you are in the circuit. You need to know what you're looking for and what you should expect to see. The book that the inventor of the load pro leads wrote is really good and I've read it a few times over. It really helped me get to the next level of understanding electricity. Something worth checking out for sure. His name is Dan Sullivan and the book is called Fundamental Electrical Troubleshooting I'm pretty sure.
A
AdamD87
I have watched a few of his youtube videos. I might just have to get the book.
motofool33
Currently North of Houston
williams part numbers with letters are usa, all numbers are taiwan.
ive got a bunch of taiwan williams its all nice equal to blue point.
abvw
Toronto, Canada
Honestly if you have a full range of 1/2" SAE impact sockets and wrenches you're pretty much set. I don't work on trucks (I'm in automotive) but I know pretty much everything is held together by 11/16"-1" fasteners. One guy I know doesn't own a single 3/4" socket yet he do kingpins and clutches with his IR2135 on 8t all day every day, the only time he's ever needed the shop's 3/4" stuff is torquing wheel seals.
Ruger_556
Severely limit what you buy before starting, within the 1st week you'll figure out what you actually need pretty quick.
Don't buy any 3/4 tools yet except maybe a ratchet which you'll need for axle nut sockets, impacts and sockets are supplied by most shops.
Extra deep 3/4 impact socket for caging brakes
Either a 5/16 8-point socket or the brake adjusting tool sold by many companies
5/8 8-point socket for differential fill plugs
36" pry bar for checking kingpins etc...
I like an adjustable pry bar for wheel seals but most guys use heel bars, the shop will likely have a wheel seal remover but they don't work worth a ****.
Long heavy punch for driving out bearing races, shop may have a race installer/remover but it won't work on all hubs.
6 or 8 lb engineers hammer
