Record (Irwin) 6VS Vice Jaws
gedgemon
I've killed several hours scouring the internet for replacement serrated steel jaws for my ~25 year old Record 6VS vice. If anyone can help me find replacement jaws, I'd sure appreciate it. The 6VS appears to have jaws with different dimensions than the more common Record 6 vice, but I'm not 100% sure on that either. Jaws on existing vice are 6" long, by 3/4" tall and about 1/2" thick. Center to center on mounting holes is 76 mm (3"). Thanks in advance... Really appreciate the folks here!
lilredex
Toronto
I bought 6" Record jaws a couple of years back from Grainger here in Toronto, for $28 CDN. They are 4" across the mounting holes. Unless you are going to put that vise to really heavy duty use, I'd just make up some from mild steel bar stock.
Where are you located.......always good to know. Welcome to the club!
G
gedgemon
6VS uses different jaws than 6V. Thanks though. Will take another look at Grainger. Bar stick an option, but I'd like the serrated faces.
