Recycling ac unit?
no704
I’m going to replace the 20 year old gas pack ac on my home. It’s a Rheem 4ton. Also building a shop probably around 35’x30’x12’. Should reuse this unit on the shop or get a new mini split?
mike93lx
Richmond, VA
20 years old must be r22, right? Do you own the equipment to capture the refrigerant? Can't imagine you will find a pro to do that and recharge the unit.
PoorUB
Fargo, ND
I would be a little reluctant to reuse it, after all, it is twenty years old.
You said gas pack? I assume it is a self contained residential packaged unit? With a package unit you don't have to recover and refrigerant to move it, so there is some thought that you will not have a whole lot of work into it.
mike93lx
Richmond, VA
Ah, yes, forgot about the packaging on those
PoorUB
Fargo, ND
You can probably sell the r22 and scrap the rest. That refrigerant it super expensive now.
Used R22 is probably worth $5 a pound. It is illegal to use it in someone else's equipment. It will cost more to recover than it is worth.
stevied916
Northern CA
I thought it was worth more but I guess I’m wrong! I remember it wasn’t cheap getting out old system recharged after a leak.
karoc
Hemphill Tx
Working for HVAV company in my younger days we would take out working systems and yes pump them down to reclaim 22. As a business and owner who care we would save those units for hardship causes , install used units. Sometimes they would start and sometimes they didn’t. I always said that unit would go into Cardiac arrest. So if you have skills then it’s worth your time, if no skills I would look into mini.
Zeke
This. People just don't read.
The unit won't be very efficient by comparison.
infinkc
if you cant use it to refill, who will pay $5?
N
no704
Not r-22. 401 I think. Probably not worth messing with.
Walkers
Cave Creek Az
A package unit is self contained, just pick it up and set it down somewhere new, just need to wire and duct t.
*edit, I see this has already been covered
mike93lx
Richmond, VA
Yeah, they aren't something I had ever seen used in New England, so I wasn't thinking about that when posting.
Two Door
Houston, TX - USA
It can be recycled.
I worked for a HVAC wholesaler and we bought and sold it to a company that cleaned it and repackaged it for resale.
What terms do you use to find someone who will do residential capture, if there even is such a niche? I have a system I want to remove as part of a DIY remodeling to make way for a mini-split. I can't find anyone to do it on a small scale, only commercial. I assume your common service guy or company just vents it, which I would like to avoid. I'm fine with paying for the service.
mike93lx
Richmond, VA
The guys that just replaced two of my r22 systems captured it. They pay for recycling when they have full bottles
PoorUB
Fargo, ND
Any HVAC company should evacuate the system, but they will charge you and keep the old refrigerant. It will probably cost you $200, maybe more.
PoorUB
Fargo, ND
Some guys will, but it is against the law to vent most refrigerant, fines up to $45,000 per day. Sad thing is I have never heard of a contractor getting fined, but some manufacturing plants have, so it appears there is not much policing going on.
N
no704
Buddy of mine that is a licensed and very experienced hvac teck will be replacing the old unit. Although he hasn’t worked in the trade for a few months. Decided to up date his cdl and drive a garbage truck. I’ll see what his opinion is. Probably go with a new mini split.
Two Door
Houston, TX - USA
My point exactly, the reason for the post. The culture around here is "Do what you can get away with."
dave*99
Coastal NJ
Nobody ever vents it on purpose....... it just "leaks out" before they have a chance to recover it.....
