Redline Smartfit coolant pressure adapters?
01ps
Has anyone tried this kit? It claims 100% coverage, but even if it does most I'd be happy. The very few reviews I found on it were positive but I'd like to hear what you think.
I work in a shop on all makes, but some I run across occasionally and don't want to buy adapters for them. We have the stepped rubber adapter but it bottoms out in a lot of filler necks so is often useless.
srmofo
SW ohio
I use a setup that has an expandable bladder for the oddball cars I work on that I don't have adapters for. Its a little finicky and I wouldn't want to use it on every car but it works great as a backup and its cheaper than buying a set of adapters
I bought it from Cornwell but I'm positive its rebranded. I can post a link later if you want I'm on my phone right now
86k10
Colorado
I bought the Redline kit complete with pressure tester and 3 rubber adapters. I have only used it on Ford, GMC, Isuzu but all 3 cases it worked fine. I have sprayed the adapters down with soapy water to check for leaks and never found any. So far I am happy with them.
