I picked up an old bench grinder that I'm going to replace the bearings on and repaint. I had to cut some of the wires to get it apart, and need to splice them back together.
What would you recommend in this case-- stripping, then soldering the two halves together, with a heat-shrink tube over them? I've done hack work wiring repair before, crimping and such, but the spaces I'm dealing with now are a little tight, and I don't want to extend the wiring much if I can help it, since it's in an enclosed space which will have a spinning rotor nearby. Too much slack and I can see things going bad.
That said, I'm open to suggestions. The existing wiring is covered in a sort of cloth tape, which gives an idea on how old the grinder is. It worked fine before I took it apart so the connections were still good.
