Reed 106 trade
Sawmill7
Iron River Mi
Just traded a small newer vise for this nice big Reed 106. This is my biggest vice so far. 2 1/2 hrs to get jaws apart, just filled with years of oil and hard grease and grime
Nothing broken but handle has a couple bends.
Are the balls on the ends pressed on or threaded?
Want to clean it up and repair handle. Thanks for any help with my question
paulsomlo
Northern Colorado
My guess is peened, but there are others here much more in the know than I - you should be able to tell by looking at the ends.
Me? I would even try to save it - I'd cut the handle off, get some steel rod and put some ends on it.
cretedog
North Dakota USA
Lay the spindle / handle assembly in a hydraulic shop press- you can slide the handle back and forth and straighten it. If you're not happy with the result you can always cut the handle off and make a new one.
Beerhippie
Far NE Oregon
Have you looked for the date stamp yet?
It's here:
and here:
The 36 is an assembly number to keep the matching parts together. The 711 is the date--July, 1911, in this case. Date is often very lightly stamped.
Sawmill7
Iron River Mi
It's here:
and here:
Was wondering about that..here a couple pics of movable jaw , I can't see anything can you? Am I looking in the right spot?
Beerhippie
Far NE Oregon
The 455 is probably an assembly number. Look in the same place on the static jaw--it should have the same numbers.
Like I said, the date stamping is often very light and easily obscured by "battle scars".
I don't recall just when Reed went from the "meatball" end on the screw to the cylindrical, but I think it was earlier than '55. Could be wrong.
Provincial
Near Salem, OR
The key to straightening bends is to figure out how it got bent in the first place, then apply pressure opposite what caused it. Allow for spring-back by bending it a little past straight. If multiple bends, try to figure out which came first, then start with last one.
Support the screw hub in a way that doesn't transfer the force to the screw itself, and possibly bending it.
Beerhippie
Far NE Oregon
Or, just let it be. It's just another battle scar and more history.
Beerhippie
Far NE Oregon
That may be what I'll do.
I figure these old fellas have earned it. My 1911 Reed is largely retired and enjoying its place of honor on the right corner of the bench:
It sees just enough use to keep it feeling like it ain't forgotten.
It even got a new party dress:
