ffast65
Need some help with an early reed 106. She is degreased on outside, derusted, primed, and painted industrial gray enamel. I was just going to clean the lead screw the spindle nut before relubricating with some moly grease. When I removed the collar, and then the spindle, I was surprised no bronze washers were on either side. Is this normal for large reeds?
or should I be putting one under the head, and then under the collar when I reassemble? I am planning to use this one, so want it correct as jaws and rest are in pretty good shape for its age/prior use.
also, how do you get the end balls off the handle? they are lose/spin free, and the handle is bent in two areas. I would like to straighten
