I’ve got a Reelcraft cord reel model number L4545-1239 that’s never been used and I was getting ready to connect it in my garage. I was going to plug it into an existing 15 amp outlet to source power, but then thought it would be a good idea to run a dedicated 20 amp circuit specifically for it. I’m in the process of pulling wire for a garage heater and thought now would be the time to pull a separate 12/2 wire just in the event I want to convert the entire garage to 20 amp.
Anyhow, I looked at the specs for the Reelcraft and it says it rated only for 15 amps. The connecting power cord and extension cord are both 12AWG, which should be fine for 20 amp…at least that’s my basic understanding of wire gauge. I then looked on Reelcraft’s site for a reel rated for 20 amp model number L4545-1237B and they are also made with 12 AWG wire. The only difference I can see is it used a bigger connecting plug for the connecting power cord and on the end of the extension.
If I wanted to use my existing reel on a 20 amp circuit, can I just upgrade the plugs?
I do plan on calling Reelcraft on Monday, but want to get opinions over the weekend.
Reelcraft 15 amp multi outlet reel
https://www.reelcraft.com/catalog/product_search.aspx?search=L 4545 123 9&category=cord-power
Reelcraft 20 amp multi outlet reel
https://www.reelcraft.com/catalog/product_search.aspx?search=L 4545 123 7B&category=cord-power
