Refillable spray cans
whateg01
doo dah, kansas, usa
Are there any refillable spray cans that are suitable for things like brake cleaner that don't use a Schrader valve? I like the hand pump on the jug I use for spraying the yard but I'm sure chemicals like brake cleaner probably aren't good for them.
alwaysFlOoReD
Airdrie, Alberta, Canada
Yes, I believe " Pump and Spray " is the name of the one I use.
danielbuck
sure-shot is fantastic for solvents. pressurize it with compressed air, or even a bicycle pump if you don't have that.
It does use a shrader valve I think, but I've never seen that be a problem. mine is only a few years old, but I know folks who have these for much longer without problems.
I know you said you like the hand pump, but these will stay pressurized for a long time, probably much longer than a can of brake cleaner lasts you.
scooby074
Nova Scotia
Genuine Pump and Sprays can take brakeclean (correct model with right materials). Sold through autoparts and Wurth. Same for Sureshots. We used a ton of sureshots at work spraying some pretty nasty solvents (xylene based) and they held up well.
