Refinishing a rusty I-beam?
StriderTB
Spotswood, NJ
I'm going to be finishing the interior of my 2 car detatched garage, and one thing I'd like to do is clean the I-beam that runs across the center of the structure. Is there a recommended way to get the rust off? I was thinking about a wire cup on a drill.
Also, what kind of paint would be best for painting it? I was thinking of something glossy and red. ;)
That pic is from my walkthrough before we bought about 2 years ago.
Colin-Roberts
wire cup on a grinder or drill would work but would take a while. I would put por 15 on it after cleaning
Nostraquedeo
I laid down plastic and used wet/dry sand paper with water. It took a while, but I got it smooth. I painted it with five coats of black fire retardant paint. Looks really good!
zer01
Sandblaster? I would tarp off as much of the area as possible and sand blast it. May be hit it with a wire wheel on a grinder before sandblasting. Wear good protection and keep area ventilated.
S
StriderTB
Spotswood, NJ
My budget for this is about $14.99 and a lot of elbow grease. ;)
I think the wire cup or one of those Gator stripping discs on a drill will be in my future.
djjsr
In the cornfields
Don't bother trying to get the rust off. Get some Rustoleum primer for rusty metal. The stuff works great, it's cheap and you probably only need a quart. Then you can top coat it with anything.
tcianci
Walpole, Ma
I have 2 I beams in my garage, one was pretty much in red oxide primer so I painted it with latex wall paint and it has stayed fine for years, the other one was for a trolley for a chain hoist and it was pretty rusty...I hit it with a wire wheel and then POR Metal ready. After that a couple of coats of POR 15 black. It's been rust free for over 10 years now and it looks nice and shiny too.
R-132 Fan
Central Texas, East of Austin
Wire cup on a drill is going to get old fast. You will do better with a 4 1/2 hand held grinder with a good quality wire cup on it. The 4 1/2 grinders from Harbor Freight are ****. For just a little bit more the Kawasaki brand grinders at Tractor Supply are a good buy. Flap wheels work well after you knock the rust down with the wire cup. You get what you pay for. I notice the cheap flap wheels from Harbor Freight don't hold up as well as the ones I pay a little more for from Fastenall or the local welding supply store.
I like the idea of Rustoleum red iron primer followed by a top coat. Make sure to keep the primer stirred up while you paint if you go that route.
DIC
Wire brush it and brush on some red oxide primer ....It covers up a lot of ugly...........:thumbup:
blue dog
Culver City Ca.
put penatrol on the rust, let it dry and then put clear epoxy on it, looks great.
and call it a day. sealed rusted steel is big now days.
Daniel Dudley
Blast the flats with a palm sander. Don't even try to remove the rust, just smooth it and blow it down. Brush on Rustoleum, no primer needed, or Sherwin Wiliams Direct to Metal.
A little roller would help a lot, and I would just Paint it if I tried a little patch and it looked OK.
