Not a garage question, but this is the only 'building' forum I am on and there is plenty of mention of it in the past.
I have a modular on pilings. The skirting is 2 inch rigid foam insulation, in 4 ft pieces, coated in stucco. The gaps are just the textured surfaces touching and maybe up to an 1/8 inch gap. It works well, but on a cold day (-30) with a good wind there is enough air transfer to drop 5-7 degrees with a few good gusts.
I was thinking the double bubble reflective insulation would be easy to work with. It would create a vapour barrier. Likely be easier to install than a floppy piece of poly and it would offer a reflective surface to reflect light when working under there.
My question is will it offer any more value than poly?
The skirting is in a channel on a treated 2x4. There will be a 3/4" gap between the bubble insulation and the back side of the skirting.
I was also wondering if I should use acoustic sealant or other goop to seal it to the ground vapour barrier and underside of the home, further stopping drafts. There are 5-7 thermally controlled vents that allow air transfer even when closed (not air tight), so there is no worry of completely sealing off the area if I go to town. Just not sure if other than looking neater, and possible longevity, if there is any benefit over poly.
Any experience to share?
Thanks fellas!
Thanks fellas!
