Our home has an outdoor fireplace the previous owner installed that uses a fireplace insert instead of a fire box constructed of fire brick. The refractory in the rear of the unit basically crumbled as soon as I looked at and needs replacing.
My problem then has become, do I replace the refractory panel in the deteriorating fireplace insert or do I rip it out and build up a proper firebox with actual firebricks instead. The fireplace itself looks rather nice but the only problem is the insert is aging. Another problem is that I have no idea what the internal structure is. Could be dimensional lumber, or it could be solid brick. The guy seems to have done some things with a mind for overkill so I'm guessing solid brick but I really won't know until I dive in.
So, how hard is it to build up a firebox in an existing structure using fire brick?
What gotchas are there and how best to avoid any in the first place?
Any advice is appreciated.
