refrigerated dryer compressor layout
shannonw
Florida
Hey all,
i'm installing a dryer after the compressor. it's rated for the psi of the compressor (175psi) but i usually regulate down much lower than that of course usually 90 but sometimes 110 for a long hose run 100feet i have to go.
should i put the regulator after or before the dryer? I'm thinking regulator should go at the end after the dryer but i'm not sure.
I'm basically thinking
tank->cutoff -> dryer->separator->regulator
or should you filter before the dryer and regulate before also? or filter before the dryer and regulate after?
Aahz
Chicago, IL
You have it right, although putting a filter between the compressor and dryer is always beneficial as well. Regulator should be downstream from the dryer.
shannonw
Florida
yep was planning on a bypass there as well and for things like blowing out the garage.
stonesfan68
Houston, TX
Put the moisture separator before the dryer. I'd also recommend putting a filter in front of the dryer so as to protect the dryer's heat exchanger.
You do have an aftercooler on the compressor?
compressor->aftercooler->tank->separator->dryer->regulator
shannonw
Florida
Hi, no after cooler (just the normal 2 stage finned pipe). That would be good eventually as the dryer is a bit undersized, the compressor is 14cfm, dryer 10cfm, it may not even work but it was cheap so i figured i'd give it a shot...I don't need 100% water free, i don't sand blast... but the single stage i had with florida humidity was more of a water hose than a compressor and i don't have the space to add a considerable amount of pipe easily without a lot of thinking =)
I'm hoping the 2 stage with a bit of pipe and and the addition of the dryer will help considerably. I have read the threads on the after cooler and it seems like it would help also.
i plan to put it a bit downstream of the compressor how far i'm not sure, i can maybe get 25 feet or so of pipe there.
shannonw
Florida
the 25 feet may even be good enough with the 2 stage to condense the water and i might not need the dryer. i haven't used this compressor a lot yet but it seems to produce lots less water in the lines, but it's cooled down a bit in florida too.
wolfsburged
Cary, NC
It seems like most of these dryers have inlet/outlet sizes of say 1/2". If one were installing a new system with the dryer, any reason to stick to 3/4" outlet size of most compressors and then neck down to 1/2" and back up? Or just stick to 1/2" throughout? Sorry to hijack a bit.
shannonw
Florida
Both of mine have always been 1/2 out and i step down to 3/8 at point of use/end of the run. As for stepping backup after the dryer i'd think it depends on the length of the run if it would be worth it...short distance i can't see how it would make any difference, long distance even though there was a short bottleneck surely on a long run the 1/2 would be less restrictive?
Aahz
Chicago, IL
They size the inlet and outlet lines of the dryer to match the size and flow of the compressor it's meant to be used with. A 5 hp-7.5 hp is 1/2", 10 hp would get 3/4", 20 hp 1" and so on. The outlet thread of the tank is usually 3/4", but when you size the piping for smaller compressors, 1/2" is all that's needed in most cases.
