ElectroPulse
- Joined
- May 23, 2015
- Messages
- 33
Hello all,
I'm getting ready to purchase a replacement for the cheap regulator that came on my HF compressor, and I've been reading around and have seen the mention of "Pressure drop" on regulators. For example (https://www.grainger.com/product/WILKERSON-3-8-General-Purpose-Air-Regulator-6B212):
"For the Max. Flow, the CFM is measured with 100 psig inlet adjusted to a set pressure of 90 psig and a 15 psig pressure drop."
The way it's worded, it sounds like some standard method used when rating a regulator's CFM... I'm just having trouble figuring out what exactly this means? Just wanting to make sure it's that (and how exactly that works into their rating system), and not that the regulator eats 15PSI in some way (coming out of a 125PSI compressor, that'd be a bit much) (and no, I'd rather not run regulator-less).
Thanks!
Thanks!
