Regulator question
trooper1954
Salmon Arm, BC, Canada
Hi, just inherited an oxy-actylene kit that was disassembled. My question is does this regulator require an o ring around the channel near the connecting nut? If so, is it a generic one or do I go to a welding store?
Thanks.
dogdog
usually CGA-*** connectors does not require any o-rings ... at least the ones in the USA. Just make sure the mating surfaces are clean and does not have any debris. For oxygen make sure NO Oil..
The different CGA-*** connectors are used for different gases, there is a chart some where. yours says CGA-320.
As far as gauges... get one for your gas.
Jack Ryan
Adelaide, South Australia
I think it is a CGA 520. A CGA 320 is for CO2 and uses a gasket.
Jack
dogdog
Jack
you are right.... hmmm then I am wondering what those soda machine CO2 uses now... oh well will find out .
and Yes OP does have CGA-520 looking at it from a computer now.
